2013 Civic fog lamp kits
Rep Power: 0 2013 Civic fog lamp kits
The factory kits are 299-400+ and I'm not convinced that they are the best choice anyway.
I would like to go with a quality aftermarket kit with clear lenses and 3000 degree bulbs. Hopefully, the kit will not be too complicated to install.
I have seen many aftermarket choices and am hoping that someone has gone there before and can provide some advise as to where best to buy these and the model that they have used.
I have also heard that the stock wiring harness already has plugs for easy installation of factory kits - is this true? If so, do the fog lights have their own relay or do they operate off the headlight relay?
Thanks for your advice.
Greg
Greg
Re: 2013 Civic fog lamp kits
If you want to check out the instructions for a factory kit, go to http://estore.honda.com/
Pick accessories, then look on the right side column for
"If you looking for installation or DIY instructions
for a purchased accessory, you can find it here "<--(that might actually link)
Hey ezone,
You seem pretty knowledgeable,
I have a 2013 Civic EX, no leather or fog lights. I am wondering if you know will switching out the piece in the middle of the dashboard(believe its the daylight sensor), and changing the turn signal lever to the one that includes Auto for the headlight setting will give my car automatic headlights?
Any info or direction would be appreciated.
Thanks.
Thanks.
carvedtop
05-24-2012 02:38 PM
93CiviCex
12-16-2011 08:17 PM
