Strange sound from new air intake
Rep Power: 0 Strange sound from new air intake
Hey guys, so i just got a short ram air intake, And after installing it I took it out on the road, sounded just like normal while accelerating gently and cycling through the gears. However when I put my foot down a little more, in the lower end of the revs it was very loud while accelerating. Not like loud air sucking, and didn't sound like any kind of leak. Just like a loud engine would sound as if i had an aftermarket exhaust. Just wondering if this is normal. Throttle feels a little more responsive than it did before. This is a 99 civic so I also have a small crack in my exhaust manifold like most people tend to get, could it just be the crack worsening? Any ideas appreciated.
Re: Strange sound from new air intake
The stock intake ductwork is designed to muffle all the noises and be very quiet.
With the aftermarket intake, you get to hear every bit of the intake sounds. It's normal.
Rep Power: 125 Re: Strange sound from new air intake
Sounds like a Hover Vac ..That is to give the false allusion of more power.... The original system on most Honda have acoustic chambers hanging off that actually do not restrict all that much. Impressive at your next race to the next red light and you don't even have to speed.
Overall, the system except maybe at WOT while silencing and since the intake is just atmospheric pressure pushing in just like in you lungs, it works pretty well. The most restriction is the throttle body and those stock ducts are larger then it.
