Can't find the right part -- radiator
Rep Power: 0 Can't find the right part -- radiator
So I can't seem to find the right radiator for my 95 lx.. I am not extremely mechanically inclined but have swapped radiators in the past on my 95 delsol and other cars but anyways.. I found a leak at the top of my radiator today when my car overheated and when I tried to find the part autozone had it but when I went to put it in I noticed that my old one only had two hoses and a reservoir line and the new one had 4 hoses and a reservoir line, one at the top and three on the bottom, I tried to call two other parts stores to see if they knew anything about it and they didn't know what I was talking about.. If anyone has any knowledge or experience with this situation please help!!!
Re: Can't find the right part -- radiator
A picture can be worth a thousand words.....
Show us what you are talking about
Dr Krieger of Modification
It could be that you purchased an automatic radiator, which would have two large hose ports, one on the top and one on the bottom; as well as two small hose ports used to cool the transmission.
If this is the case you do not need to worry about the transmission cooling ports. They do not hold coolant but rather ATF so leaving them open will not lead to coolant leaking out.
You may want to cap the transmission cooling ports just to keep them clean if you ever need to re-sell the radiator.
Otherwise It is possible that you purchased a radiator segment intended for AC, The same concept applies as above, you won't need to worry about coolant leaking.
I would fill the radiator with water and see if any think leaks out of the extra holes.
Seems like aftermarket does not supply radiators without a trans cooler anymore, because it reduces inventory needs and whatnot.
usajags84
15
08-19-2015 03:12 AM
hokiedad4
05-03-2015 10:06 PM
