how to install a grille?
Ultimate Member
Rep Power: 0 how to install a grille?
okay so im a noob when it comes to this stuff. What do i do to install a grille onto a 04 vic? any links or instructions that help equal rep and points
Rep Power: 0 i think you basically follow these instructions
http://www.7thgencivic.com/forums/sh...d.php?t=155290
here's a thread about it
nvm, wrong link...someone a few posts down got the right one
Rep Power: 278 Yeah its pretty simple. You just gotta take off the front bumber. If you open the hood you will see some plastic clips. Pop those up with a flat head and remove them...I belive there are 4. Then go down into the fender walls and you will see a screw with some more of those plastic clips. Remove these as well...Just remove the plastic clips that looks like they hold the bumper. Then move down under the car. You will see the front air dam (rubberized piece thats held in by some screws and pressure fitted. Remove this as well. I kept mine off I think it looks better...just my opinion. Once that is removed you will see some more of those plastic clips. Prepare to cut these. Its no big deal if you do you can either replace them or just keep em cut. I just left mine cut. Now its time to remove the bumper. Just start pulling from the corners. It should come off with not much force. If you feel pressure just slow down and take a look you might have missed a clip. Once the bumper is off place it on something soft...preferably an old blanket. The bumper scratches easily, so be careful. Now once the bumper is removed. You will see the stock grill held on by some screws. Remove the stock grill and put the new one on. Then place the bumper back on and replace all clips and screws. Wallah you have a nice new grill.
Go Team Venture!
1 Post
Rep Power: 287 http://www.7thgencivic.com/forums/sh...d.php?t=191909
it feels like i just answered this question.. o wait.. i did... (01-02-03-04-05 all the same when it comes to how to do it... 04-05 are different from the rest as far as shape but instructions are the same)
Rep Power: 253 good luck!
good luck installing, but by looking @ pics I REALLY dont think it will work.
The 01-03 grill is much more angled, where the 04 is a smooth curve for the most part.
it won't work...for sure
I tried JDM Ferio Grill on USDM sedan and I already had hard time! because JDM is 1cm smaller at some places.
so you will have extremely hard time to fit 01-03 grill to 04
Rep Power: 131 Thread
mjdiaz89
06-21-2016 09:26 PM
OptimisticWay
46
10-15-2015 02:16 PM
17
07-23-2015 11:48 PM
EM_WON
07-22-2015 06:49 PM
