header install Q
Rep Power: 0 header install Q
I'm going to install my kamikaze header this weekend and was wondering if I should go ahead and buy exhaust mani gasket and doughnut before I get started. Never done this before. Is it possible to reuse the old gaskets?
Escaped Convict
Rep Power: 343 general rule of thumbs is to replace them whenever you swap header, whether aftermarket or OEM.
but the general rule of thumb is also suggested cuz you only swap header, exhaust components when there are problems with it.
of course if you've only driven like 1,000 miles and youre swapping your header for an aftermarket one, your stock gaskets are probably fine.
but doesnt hurt to swap it now.. when you unseat those things, funky things happen. in either case you can make the call when you take a look at the gaskets.
wrapping may help, but in our situation.. I think it doesnt do as much as it would... and may damage your header in the long run due to extra stress and heat on the header.
so you should probably just leave the wrap alone.
Escaped Convict
Rep Power: 343 also, remember to torque the bolts probably, the stock spring bolt is rather delicate and snaps easily.
do a search on "bolt torque" and or "header torque" and you should find numerous threads with torque spec on the bolts, if you dont know them or have reference to them.
Rep Power: 503 I used my stock one when I installed the hp top portion header. You can see the link to my DIY in my sig.
Custom Titles are played out
Rep Power: 0 Thanks for the info. I installed it last night. I reused the exhaust mani gasket, but the oem doughnut wouldn't fit on the header down pipe. I took the header and oem doughnut to autozone, they looked for one that would fit without any luck. They let me go through thier stock and I finally found a winner, but I didn't check what car it was made for. Anyway, it's installed with no leaks yet and no cel (got a mil eliminator from bigjosh).
Rep Power: 0 When I did mine I went ahead and got a 3 inch donut gasket, I trimmed a lil' off the sides of the gasket to make it fit right because it was too small I think. G job on the install
mjdiaz89
06-21-2016 09:26 PM
OptimisticWay
46
10-15-2015 02:16 PM
17
07-23-2015 11:48 PM
