5w 20w Motor Oil
Old 08-22-2004
sttaylor's Avatar
sttaylor is an unknown quantity at this point
5w 20w Motor Oil
I was just wondering what motor oil I should use. The specs say 5w-20W. Does anyone use 5w-30w Mobil 1? I haven't found 5w-20w in stores.
Old 08-22-2004
streetglower's Avatar
welcome to the boards, search around first next time, there are many threads about what oil to use. You can use pretty much anything. I use mobil 1 10W-30. As for the 5w-20, you can use 0w-20, it is the replacement for 5w-20. And yes alot of people use mobil 1 5w-30.
Old 08-22-2004
civicfrenchie's Avatar
civicfrenchie is an unknown quantity at this point
Wal-Mart sells pennzoil 5w20 (dino) cheap and very reliable for daily driving...good additive package since 5w20 is thinner than 5w30 at the beginning...but at the end of the interval period 5w30 are often more degraded than 5w20 because of the additives of the 20 weight...if you want synthetic, mobil 1 5w30 is good since it's a thin 5w30 or castrol syntec 0w30(german made) both are popular for the week-end racers...
Old 08-22-2004
dragoon's Avatar
5w30 mobil 1 here.
Old 08-22-2004
Jo_Boo's Avatar
Jo_Boo is an unknown quantity at this point
I prefer Mobil 1 0w-20.
Old 08-23-2004
bobbyd's Avatar
bobbyd is an unknown quantity at this point
0W-20 Mobil One since that is what they suggest for Honda 5W-20 oil.
Old 08-23-2004
02ciVike's Avatar
02ciVike is an unknown quantity at this point
0W-20 Mobil One
Old 08-23-2004
Flashlightboy's Avatar
Flashlightboy is an unknown quantity at this point
Redline 5W-20 is used. M1 0W-20 is also highly recommended.
Old 08-23-2004
ctx66's Avatar
ctx66 will become famous soon enoughctx66 will become famous soon enough
i use red line 5w-20 but id recommend motorcraft 5w-20 syn blend which is only around 1.40qt at walmart and is a very well built oil
Old 08-23-2004
Silversleeper's Avatar
Silversleeper is an unknown quantity at this point
^ Well built oil, haha!
I use whatever I feel like using. I do that mainly because I don't really know what is ideal for my sometimes pushed Civic. Therefore, I think I will follow everyone else's lead and start using Mobil 1 0W-20.
Old 08-23-2004
ctx66's Avatar
i dont get it, whats funny
Old 08-23-2004
MIT
MIT's Avatar
MIT is an unknown quantity at this point
5w-30 Mobil 1 here, most peps said that 0w-20 is too thin.......well, you decide!
Old 08-23-2004
2K1Civic17"Gabe's Avatar
Your supposed to use synthetic in our cars. I dont do my oil changes, I have a trustworthy shop for little things. But most shops wont ever tell you to use synthetic, but if you dont always use it, your gonna have some probs down the line from the material our engine is made out of. Use the specs from the car, and synthetic, and you will be good. It will drive much better, and you dont need another change for up to 7500 miles
Old 08-23-2004
bobbyd's Avatar
The material our engines are made of? Aluminum? You lost me.
Old 08-23-2004
ctx66's Avatar
depends on which part of our engines you talk about, theyre made of lots of different materials.
Old 08-29-2004
StealthCivic's Avatar
StealthCivic is an unknown quantity at this point
5w-20 castrol gtx....car runnin smooth bro........read your manual or call honda techs and ask, 5w-20 , better gas mileage, recommended for our civics...synthenic= waste of $$$
Old 08-29-2004
VTEC MASTER
redvtec04's Avatar
redvtec04 should not be trustedredvtec04 should not be trusted
Poor some of the regular dino oil- 5w20 in a cup. its like water !!! no way id ever use that crap unless it was Amsoil 5w20 full synthetic. It is the documented best oil in the world!!!
Old 08-29-2004
ctx66's Avatar
documented by who? red line 5w-20 beats the **** out of amsoil
Old 08-29-2004
I believe the honda manual.......no need for synthetic or all that other expensive oil
Old 08-29-2004
Stealth,
The manual calls for all Honda fluids, parts and services at the dealership. It would be a fair statement to say that you don't follow everything in the manual, isn't it? You probably don't believe everyting the manual says if you're not following it word for word because you've researched or developed an informed opinion on the subject. Undoubtedly that's why you installed your K&N filter, no?
BTW, the manual does give the Good Housekeeping Seal of Approval to synthetics.
Old 08-29-2004
OMNES AD UNUM
jttegx's Avatar
weather can also be an issue when deciding with which type of motor oil. i use mobil 1 fully syn 5w-30 and its hot here in cali nowadays. wooo
Old 08-29-2004
OMNES AD UNUM
jttegx's Avatar
with synthenic, you get more miles out of it. i use mobil 1 5w-30 and change every 5000 miles while if i were to use non-syntenic, i would play it safe and get 2500miles after the non-syn oil change.
Old 08-29-2004
I wish I was asian
cambo's Avatar
most misinformed post in this thread.
Old 08-29-2004
gotrice's Avatar
gotrice will become famous soon enough
honda says that using any application other than what is specified for the vehicle in the handbook will void warranty. honda has told me that if i ever had a problem with the car in relation to oil or any problem that could be related that my warranty would be voided and they would charge me for service
Old 08-29-2004
gotrice,
That is only partially correct. If you are using the equivalent to the product offered by Honda that meets their specs, the burden will be on them to prove the non-Honda product caused the problem.
Honda says to use their fluids. Does that mean using any other brand of say, DOT 4 brake fluid, that meets the same spec as Honda results in warranty denial? Not at all.
Old 08-29-2004
Originally Posted by Flashlightboy
Stealth,
Yea Flash,
I agree with ya man...honda wants us to buy their products for $$, but what I am saying is the guidelines for standards are set = use 5w-20 grade, you can use whatever brand you determine is good or researched, like I have, I choose castrol 5w-20, I am saying I do believe we should be using 5w-20 for max efficiency and best on our engines. I still believe synthetic is good, but uncessary unless you are racing. Yes, that is why I have the k&n , but I didn't do too much research, after all gearbox has said it filters poorly....and mine is still in for 2 years!
i agree, that weather does factor in with type of oil, but 5w-20 is still best for our cars in all weather areas and I do change my oil around 5,000 miles to be safe..
Old 08-30-2004
Stealth,
Whew.... You had me worried for a minute. Glad to see you're onboard.
Old 08-30-2004
Bone Stock!
dalaw's Avatar
Isnt there a law that prohibits automaker from voiding warranty for use of fluids that is not made by the manufacturer?
Old 08-30-2004
supernootz's Avatar
supernootz is a jewel in the roughsupernootz is a jewel in the roughsupernootz is a jewel in the rough
According to who?
Old 08-30-2004
gotrice's Avatar
with honda you never know what bs they will throw at you. i personally dont trust honda to service my car unless they are doing it for free, not even the supposedly maintanace they do which is bs from what i know. i have friend that works at a acura dealership and its just about the same
Quick Reply: 5w 20w Motor Oil
