Go Back   Honda Civic Forum > GENERAL > Other Honda Civic Parts and Products
Other Honda Civic Parts and Products Post new products, talk about parts other than Honda Civic electrical, drivetrain and Suspension. This forum is only for Other Honda Civic Parts and Products.
Welcome to civicforums.com!
Welcome to civicforums.com.
LinkBack Thread Tools
Old 07-02-2009   #1 (permalink)
fortzeu
New Member
fortzeu is an unknown quantity at this point
Camber kits problem
I was wondering, what really is the difference between OEM and after market camber kits? Mine is a 1997 Honda civic coupe which is lowered. I don't know what camber kits should I buy so that the wheel alignment would match the manufactures specs. To remove this ad, register today for free or log in if already registered!
fortzeu is offline   Reply With Quote
Sponsored Links
Old 07-02-2009   #2 (permalink)
TRIZ
Hey! Look At Me!! I'm a Supporting Member!!Administrator
TRIZ's Avatar
TRIZ has much to be proud of TRIZ has much to be proud of TRIZ has much to be proud of TRIZ has much to be proud of TRIZ has much to be proud of TRIZ has much to be proud of TRIZ has much to be proud of TRIZ has much to be proud of TRIZ has much to be proud of TRIZ has much to be proud of TRIZ has much to be proud of
Send a message via AIM to TRIZ
Re: Camber kits problem
Aftermarket camber kits are adjustable, the stock on isnt. The lower the car goes, the more adjustment the rear wheels need because they tend to tip inwards. The lower you go the more adjustment you'll need. If you plan on dropping an inch, then any adjustable kit will do, if you want to slam it and tuck the rubber under the fender you'll need a lot more adjustment. The amount of adjustment is measured in degrees.
TRIZ is offline   Reply With Quote
Old 07-02-2009   #3 (permalink)
murda_civic26
Member
murda_civic26's Avatar
murda_civic26 will become famous soon enough
i got the megan racing adjustable upper control arms for my 97 ex coupe. it ran me about 100 dollars. They are adjustable for stock, up to 4 inches of lower. My car is pretty low as you can see, my fender eats my tire and megans work great! I was having an issue of serious tire depletion on the inside edge. My $150 each tires were destroyed after 10,000 miles. If you lower, you need a camber kit. Go on ebay and type in this item number :180375392161.
ID:	76819   Click image for larger version
__________________
Death by spoon
murda_civic26 is offline   Reply With Quote
Old 07-08-2009   #4 (permalink)
fortzeu
New Member
Should I buy only the rear camber kits or both rear and front?
Old 07-09-2009   #5 (permalink)
gearbox
Super Moderator
gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future
usually the fronts do not need adjustment, but its cheap enough so might as well get it. its just a pair of camber bolts that are adjustable. the rear is the most important.
__________________
Restore Performance, Reduce Costs
www.lubecontrol.com
Are you using the new soy based fp-plus?
________________________________________
Go Here For Real Medicine
http://www.youngliving.com/
Member 1025782
Jobs wanted in boulder or louisville colorado.
PM me if you know companies that are hiring.
gearbox is online now   Reply With Quote
Old 07-09-2009   #6 (permalink)
metalviper
Diamond Member
metalviper's Avatar
metalviper is just really nice metalviper is just really nice metalviper is just really nice metalviper is just really nice
Send a message via AIM to metalviper
he has a 6thgen. they use an uca and not cam bolts to adjust camber in the front.
spc and ingalls make good kits, but ive seen a lot of ppl run skunk2 as well. its recommended in the front but a lot of ppl use the washer trick for the rears
__________________
"It's not hard, it's just not easy"
!!!!7thGen!!!!
Koni/GC 6.6kg Front 9.2kg Rear, Ksport camber/caster plates, Megan rear Camber Kit, eBay Fogs, DIY Blacked out headlights, JVC KDAR-480 HU, DIY Red LED Dash Lights, DC5 sidemarkers, magnaflow exhaust, EP3 Seats, Skunk2 Rear LCAs, progress rear bar....more to come
BUY STUFF! http://www.civicforums.com/forums/19...her-stuff.html
metalviper is offline   Reply With Quote
Old 07-10-2009   #7 (permalink)
murda_civic26
Member
i got the megans after i used the washer trick. The washer trick does not work! i was riding down the road and my rear passenger side arm came unbolted. It was not pretty. That happened because the washers busted and the bolt was loose therefor rocking back and forth which backed the nut all the way out and it came off. Just get the camber kits. They are worth the money.
__________________
Death by spoon
Tags
1995 , 1997 , 2000 , 2003 , 2007 , adjustments , camber , civic , honda , kit , kits , lowering , problem , problems , si
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
User Login
Our Partners
used new
Top 10 Threads
The Super Mega Ultra Post
UPDATE: Dual-groove pulley INSTALLED!!!
Rate Your Exhaust
Rate your intake
***Poll*** which exhaust should i get? Please read info!!!
Official ENGINE BUILD TOGETHER EVENT!!!
My KMS P&P head
Exhaust Clips **Updated 02/23/05**
New Carbon Fiber Parts!
HP Header installed (pics) EX DIY updated AGAIN with performance review
Site Supporters
aluminum radiator
Honda car spoilers
