Other Honda Civic Parts and ProductsPost new products, talk about parts other than Honda Civic electrical, drivetrain and Suspension. This forum is only for Other Honda Civic Parts and Products.
Welcome to civicforums.com!
Welcome to civicforums.com.
You need to do some more research...an LS transmission is completely different from a Type-R transmission. Not only in gearing, but the R comes with an LSD. A GSR has shorter gearing and should work, ITR is the best option for even shorter gearing & the LSD (faster accell, not so great on the highways), and an LS has long gears for mileage, not acceleration. It's a bit of a waste to put all that time into the motor and have an LS transmission. A GSR is a nice middle ground, IMO. I daily drive with one, and although 5th is a little short for my liking on the highway, I enjoy the acceleration.
To answer your question, I am pretty sure that they will fit together, (either trans).
One more thing though...in your profile pic you have an 01-03 Civic...you're not looking to put this motor in that car are you? Because if so you REALLY need to do some research.
The B18 LS motor w/ VTEC head is reffered to as an LSVTEC, and the B20 is generally referred to as a CRVTEC, which will make your searching easier.
__________________
1997 Integra, Built N/A B18C1, 11.6:1 CR, tuned on a Hondata S200/ P28
2001 Civic EX, Ksports, Magnaflow Exh., SRI, SS - SOLD
The LS, GSR, and Type-R are all different motors and trannys.
There is not such thing as a GSR Type R Head, or an LS Type R Trans. You can install ITR internals in a GSR, but they are not the same. You should probably check out Honda-Tech for more info, or a forum with al ittle more support for older motors. You won't find too much info here on B-Series.
__________________
