Go Back   Honda Civic Forum > GENERAL > Other Honda Civic Parts and Products
Reload this Page
Best head gasket? Please answer ASAP. Thanks!
Other Honda Civic Parts and Products Post new products, talk about parts other than Honda Civic electrical, drivetrain and Suspension. This forum is only for Other Honda Civic Parts and Products.
LinkBack Thread Tools
Old 11-20-2008   #1 (permalink)
eknibbler
New Member
eknibbler's Avatar
eknibbler can only hope to improve
I have blown the head gasket in my boosted LS (B18B). What is the best head gasket to go with when you're pushing 15+ PSI? Need to get one soon so please help!
eknibbler is offline   Reply With Quote
Sponsored Links
Old 11-20-2008   #2 (permalink)
baron340
Member
baron340's Avatar
baron340 has a spectacular aura aboutbaron340 has a spectacular aura aboutbaron340 has a spectacular aura about
Re: Best head gasket? Please answer ASAP. Thanks!
why did you put this in the 7th gen section? i dont know for certain on the b series, but for the d17 the oem gasket is far and above the best one made.
baron340 is offline   Reply With Quote
Old 11-20-2008   #3 (permalink)
eknibbler
New Member
eknibbler's Avatar
Didn't see the section name. All I saw was "Forced Induction and...". So, there is no aftermarket gasket better than OEM.
Old 11-20-2008   #4 (permalink)
ronaldo9
Platinum Member
ronaldo9's Avatar
ronaldo9 should not be questionedronaldo9 should not be questionedronaldo9 should not be questionedronaldo9 should not be questionedronaldo9 should not be questionedronaldo9 should not be questionedronaldo9 should not be questionedronaldo9 should not be questionedronaldo9 should not be questionedronaldo9 should not be questionedronaldo9 should not be questioned
Cometic? Do you have arp headstuds?
ronaldo9 is offline   Reply With Quote
Old 11-20-2008   #5 (permalink)
eknibbler
New Member
eknibbler's Avatar
Yes. The motor is fully built to include the ARP studs.
Old 11-20-2008   #6 (permalink)
ronaldo9
Platinum Member
ronaldo9's Avatar
Another thing to consider is check your tune. Detonation could be a cause for a blown headgasket.
Old 11-20-2008   #7 (permalink)
eknibbler
New Member
eknibbler's Avatar
880 cc injectors keep it running rich. Almost too rich. All spark plugs look fine though.
Old 11-20-2008   #8 (permalink)
ronaldo9
Platinum Member
ronaldo9's Avatar
What engine management system are you using just curious?
Old 11-20-2008   #9 (permalink)
gearbox
Super Moderator
gearbox has a brilliant futuregearbox has a brilliant futuregearbox has a brilliant futuregearbox has a brilliant futuregearbox has a brilliant futuregearbox has a brilliant futuregearbox has a brilliant futuregearbox has a brilliant futuregearbox has a brilliant futuregearbox has a brilliant futuregearbox has a brilliant future
you dont want a beefy headgasket. if it doesnt give out when it should, you could blow up the motor. obviously theres a problem if it blew in the first place, id figure out why first before just wasting time replacing it.
gearbox is offline   Reply With Quote
Old 11-20-2008   #10 (permalink)
eknibbler
New Member
eknibbler's Avatar
Driving the other day and turbo sucked in some water which bogged the engine down for a little bit (did not hydrolock), but the car ran fine for about a week. Then, we raced a Jetta last night and it was skipping because an injector plug had popped loose while we were racing. We stopped, popped it back in, and it ran fine until the head gasket blew.
Old 11-20-2008   #11 (permalink)
eknibbler
New Member
eknibbler's Avatar
Quote:
CHROME
Old 11-21-2008   #12 (permalink)
td-civ
New Member
td-civ is an unknown quantity at this point
as long as you have a good decked head arps head studs you should be fine for like 20 psi
Cometic makes the best one
td-civ is offline   Reply With Quote
Old 11-24-2008   #13 (permalink)
ampong
Member
ampong's Avatar
ampong has a little shameless behaviour in the past
well for sure the best gasket will be the OEM but it is a bit pricey.
ampong is offline   Reply With Quote
Old 11-24-2008   #14 (permalink)
eknibbler
New Member
eknibbler's Avatar
Long story short, Sleeve cracked and head gasket fine. Got to love the boost.
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
User Login
Our Partners
used new
Top 10 Threads
UPDATE: Dual-groove pulley INSTALLED!!!
The Super Mega Ultra Post
Rate Your Exhaust
Rate your intake
***Poll*** which exhaust should i get? Please read info!!!
Official ENGINE BUILD TOGETHER EVENT!!!
Exhaust Clips **Updated 02/23/05**
My KMS P&P head
New Carbon Fiber Parts!
HP Header installed (pics) EX DIY updated AGAIN with performance review
Site Supporters
aluminum radiator
Honda car spoilers
Powered by vBulletin® Version 3.6.8
