The cams are new, no part numbers yet.
> You'll have to order direct as no dealers have the
> cams at this time.
> Turbo spec will feature a 188 duration, .238" lobe
> lift, .405" gross lift.
> >> Stock D17A2 cam specs:
> >> Int Mid (VTEC) - Dur @ .050" is 184, lobe lift .199"
> >> Exh Lobe - Dur @ .050" is 170, lobe lift .163"
> >> Stage 2 N/A Crower spec:
> >> Int Mid - Dur @ 050 193, lobe lift .237
> >> Exh Lobe - Dur @ 050 180, lobe lift .190
> >> Looking at about $375 per cam + required
> >> spring/retainer kit (#84166) runs $302.
> >> Thanks for your interest in Crower,
> >> Crower Cams & Equipment Co, Inc
> >> 6180 Business Center Court
> >> San Diego, CA 92154-5604 USA
> >> Tel: 619-661-6477
> >> Fax: 619-661-6466
http://www.crower.com
