Go Back   Honda Civic Forum > GENERAL > Other Honda Civic Parts and Products
Other Honda Civic Parts and Products Post new products, talk about parts other than Honda Civic electrical, drivetrain and Suspension. This forum is only for Other Honda Civic Parts and Products.
Welcome to civicforums.com!
Welcome to civicforums.com.
LinkBack Thread Tools
Old 01-06-2005   #121 (permalink)
kornsined
Ultimate Member
kornsined's Avatar
kornsined is a jewel in the rough kornsined is a jewel in the rough kornsined is a jewel in the rough
Send a message via MSN to kornsined
nice. how are the gains with the full header? To remove this ad, register today for free or log in if already registered!
kornsined is offline   Reply With Quote
Sponsored Links
Old 01-06-2005   #122 (permalink)
DaRk_MauL
Super Member
DaRk_MauL is a glorious beacon of light DaRk_MauL is a glorious beacon of light DaRk_MauL is a glorious beacon of light DaRk_MauL is a glorious beacon of light DaRk_MauL is a glorious beacon of light
Send a message via MSN to DaRk_MauL
i like the full header it does his work as speaking.tested it against a stoch d17 vtec
and i gain a nice distance till 220km/h dont know exacly how many miles/h that is.
I can say that its a difference at all rpm an it gives some more at high rpm!for now
its working for me till i get boosted...
grtz
DaRk_MauL is offline   Reply With Quote
Old 01-09-2005   #123 (permalink)
Nimnus
New Member
Nimnus is an unknown quantity at this point
grtz
Hi, can advice the brand of the o2 sencor module ? Tks.
Nimnus is offline   Reply With Quote
Old 01-16-2005   #124 (permalink)
ManUtd0018
Senior Member
ManUtd0018's Avatar
ManUtd0018 is an unknown quantity at this point
Send a message via AIM to ManUtd0018
I bought the HP racing header with cat and i'm experiencing some lagging. Let me explain:
After installing the header, which was super difficult, I connected the o2 sensors without the o2 sims that they provide. I was dumb and didn't know what they were for, and it was late. Regardless, the header hit against the front frame of the car and would vibrate when i braked or when the engine moved forward. So, I removed about a 1/4 inch of frame, melted it off with a torch, where it hit; no biggie.
Vibrating solved. When I drove the car things were fine, no lagging at all, but then after a day the engine light came on. So I call HP and ask them what the little boxes with wires are for and why they are needed. I find out they are o2 sims and trick the engine, and without them my car will lag.
So, i install them according to their directions, but the directions don't say which white wire to connect the o2 sim to since there are two white wires coming from the o2 sensor. So, i connected it. Reset ECU. But know after three days of driving, including freeway driving, the car lags. It seems as if it is not getting enough gas.
I call HP and tell them. Damien, the guy at HP, tells me that I might need a Super AFC fuel 'something or other' in order to opent the fuel line more and for longer.
I decide to give it another day or two, thinking that maybe the ecu is dumb and that it'll adjust to the new extraneous amount of exhuast. Today, the engine light came on!!
Help. Logically, it must be the o2 sims because it was not lagging before i put them on.
Anyone experience this? Did i install the o2 sims wrong?
Also, the header had two locations on the primary tubes for o2 sensors and a third on the "cat" itself. HP said you should plug one. DUH!!! but they don't provide that, and Damien said that a spark plug works. I can't believe they don't provide something to plug the second 02 sensor location on the header
__________________
White Civic EX 02
ManUtd0018 is offline   Reply With Quote
Old 01-17-2005   #125 (permalink)
kornsined
Ultimate Member
kornsined's Avatar
yeah it has to be the o2 sims and that hole that needs to be plugged. i don't know why they didn't provide a plug. stupid IMO. i have no experience with the o2 sims so can't help you there. search for a DIY maybe.
Old 01-17-2005   #126 (permalink)
Pb4uGo
Member
Pb4uGo is an unknown quantity at this point
Send a message via Yahoo to Pb4uGo
Quote:
Originally Posted by ManUtd0018
HP also has directions using the colored wires in the rear o2 harness, which are all their own color. Use those to make sure you are wired in correcty for the o2 Sim.
Aye, it is a shame about the extra bung, but you could keep the factoryo2s up front and put a wideband sensor into the rear bung. I just plugged it with an extra o2 sensor I had laying around. Having lots of broken cars has it's advantages
__________________
www.StreetRays.com
Daily: 2001 Civic EX Sedan
Race:Built F22B1 SOHC VTEC 420whp/390wtq with no chassis
Pb4uGo is offline   Reply With Quote
Old 01-19-2005   #127 (permalink)
DaRk_MauL
Super Member
i didnt used the o2 module and i have no problem because some @ honda-tech
explained to me that this module just makes your ecu believe that your cat is working
that is al.
Old 01-20-2005   #128 (permalink)
ManUtd0018
Senior Member
ManUtd0018's Avatar
I just removed the o2 sims and the lag is gone.
__________________
White Civic EX 02
Old 01-20-2005   #129 (permalink)
ManUtd0018
Senior Member
ManUtd0018's Avatar
It feels as if i lost torque but gained on the high end.
__________________
White Civic EX 02
Old 01-20-2005   #130 (permalink)
kornsined
Ultimate Member
kornsined's Avatar
let it adjust for a few weeks and see. although i thought it would lose more torque then the top portion only header.
Old 01-20-2005   #131 (permalink)
ManUtd0018
Senior Member
ManUtd0018's Avatar
Do you really think that it will take nearly two weeks for the ecu to adjust? i reset the computer already.
__________________
White Civic EX 02
Old 01-20-2005   #132 (permalink)
kornsined
Ultimate Member
kornsined's Avatar
yeah i think so or a least a couple tanks of gas. i mean nothing earth shattering in difference but a enough to know how it has responded to the mod.
Old 03-19-2005   #133 (permalink)
Danger Mouse
Tejas PimP
Danger Mouse's Avatar
Danger Mouse is just really nice Danger Mouse is just really nice Danger Mouse is just really nice Danger Mouse is just really nice Danger Mouse is just really nice
Send a message via MSN to Danger Mouse Send a message via Yahoo to Danger Mouse
~ I had a question for IronFist or whom ever is able to answer, about the header and O2 sensor. I bought a Ceramic Focuz Header and it has a spot in the side of it for what appears to the O2 sensor.. but when you remove the heat shield the sensor is below the header, in what I would assume is the manifold. Question is: When you remove the stock header to add a(n) aftermarket one, does the manifold come off? I bought my header used and there are no instructions with it and I have been unable to find a "Focuz" website to look at instructions. Any imput you guys can give me would be greatly appreciated. Thx ~
__________________
Eminem's critics say his lyrics are violent and offensive to women and homosexuals.
House Fund $2007.56
Bike Fund $733.39
Danger Mouse is offline   Reply With Quote
Old 03-19-2005   #134 (permalink)
kornsined
Ultimate Member
kornsined's Avatar
ok first is this a top portion header or a full race header? what model do you have, LX or EX?
Old 03-19-2005   #135 (permalink)
Danger Mouse
Tejas PimP
Quote:
~ '03 EX ~
~ errr - what ever piece is right behind the heat shield infront of the fan ~
__________________
House Fund $2007.56
Bike Fund $733.39
Tags
01 , 03 , civic , diy , downpipe , exhaust , header , headers , hp , increase , install , installation , o2 , original , pic , pics , si
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
User Login
Our Partners
used new
Top 10 Threads
The Super Mega Ultra Post
UPDATE: Dual-groove pulley INSTALLED!!!
Rate Your Exhaust
Rate your intake
***Poll*** which exhaust should i get? Please read info!!!
Official ENGINE BUILD TOGETHER EVENT!!!
My KMS P&P head
Exhaust Clips **Updated 02/23/05**
New Carbon Fiber Parts!
HP Header installed (pics) EX DIY updated AGAIN with performance review
Site Supporters
aluminum radiator
Honda car spoilers
