New head unit settings
Old 05-09-2016
Mikeyyy's Avatar
Mikeyyy is an unknown quantity at this point
Question New head unit settings
Ok I went out and had a new cd receiver and some decent speakers installed and now trying to figure out what settings to use.
it has a high pas filter that changes slope level by -12 or -24 db for 50, 63, 80, 100, 125, 160, 200 hz
also has an equalizer that ranges -6 to +6 in 80hz, 250hz, 800 hz, 2.5khz, 8khz
I have been playing with it but still confused. I can make 2 custom EQ curves and there are 5 preset ones that can't be changed.
Any help??
Old 05-10-2016
drhawkinz's Avatar
drhawkinz has a spectacular aura aboutdrhawkinz has a spectacular aura about
Re: New head unit settings
most of that is to just tune the sound how you want. I'm using the HPF because I have blown stock speakers and the low fqz make them rattle too much.
If you have subs you can also use the HPF so that you're small speakers aren't trying to play sounds at 60 or 80hz without proper power.
But the settings are whatever you want. You can probably see the EQ curve for the presets and then tune it from there. I like the "powerful" setting for mine but with a little less bass to save the speakers.
nateschisler
07-25-2016 06:17 PM
prr
05-08-2016 07:53 PM
Logan Chou
04-28-2016 09:32 PM
kike
04-21-2016 03:05 AM
djkamar
04-14-2016 09:33 AM
Quick Reply: New head unit settings
