Identiying Ignition Sense Connector (Under-dash fuse/relay box end)
Rep Power: 0 Identiying Ignition Sense Connector (Under-dash fuse/relay box end)
Hi all!
I try to identify Ignition Sense Connector from Civic 4D (8-th gen, model of 2005 for Europe). This connector plugs into Under-dash fuse/relay box, have light green body, contains 2 pins and brings IG1 (blue wire) to the car.
Please see pictures attached. Position # D.
This connector a little bit wider than 1" (~26-27 mm) and contains 2 huge female pins, about 3/8" (10 mm) wide.
I need to know name of connector manufacture and, if possible, connector name/series. But even mfg. name will be very helpful.
Any help will be appreciated!
Re: Identiying Ignition Sense Connector (Under-dash fuse/relay box end)
Honda doesn't tell us that info.
I'd think one could locate some appropriately sized female spade terminals and connect them into the fusebox without the plastic housing, but you'd need to secure the wiring in such a way that they can't vibrate out.
Check an auto recycler (junkyard), locate similar car, cut off the wires/connector you need, then splice to your harness?
Rep Power: 0 Re: Identiying Ignition Sense Connector (Under-dash fuse/relay box end)
Thanks, but I need exactly connectors and new pins. To make some custom jumpers.
I know that Honda don't share P/Ns of third-party components used, but maybe somebody knows for e.g. that favourite supplier of connectos for Honda is JST or maybe Molex? It will narrow my search.
Default_Slayer
Electrical DIY
12-04-2022 07:56 AM
wankers
01-20-2019 06:44 PM
WKD DRGN
06-18-2015 07:56 AM
