shielding an RJ11 cable from side pillar airbag
Rep Power: 0 shielding an RJ11 cable from side pillar airbag
I just bought a 2013 civic, with side pillar airbags. I have a valentine 1 radar detector and I want to install the RJ11 power cable along the driver side pillar, where the airbag is at, will that be a problem? Can the cable emit or cause any electrical impulses to activate or cause the side pillar airbag to deploy?
The RJ11 cable is plugged into the 12V cigarette lighter and the radar detector.
Do I need to shield the cable, or what would I even shield it with?
I have attached a picture as well to make it easier to know what I am asking.
Any advise, or any thoughts?
Thanks, Dan
Thanks, Dan
Re: shielding an RJ11 cable from side pillar airbag
No problem at all. The inflator (explosive charge) portion of the bag isn't in the forward pillar.
Our dealer accessory remote starts have the antenna cable run up the drivers pillar.
You probably should avoid draping your wire across the inflatable bag portion (which extends about halfway down the pillar), simply because it might be an obstruction in the event of a deployment.
You may just have to tuck your wire around the trim as there is a big trick to getting the trim off, the top fastener is non-reusable.
If you want to know how to get the trim off, look up accessory installation instructions for a remote start on that car. You can find instructions through this site: http://estore.honda.com/
HTH
HTH
Rep Power: 0 Re: shielding an RJ11 cable from side pillar airbag
Thanks for the quick reply.
So what is the accessory remote cable that you mentioned? Does that carry electricity on it?
I'm not really worried about the RJ11 cable being in the way if the airbag deploys, I'm just worried that I don't want the RJ11 cable to cause the airbag to deploy for not reason.
I don't think I'm the only person or first person to install a this cable for a radar detector, I just couldn't find any other posts on this type of question on there.
Thanks, Dan
Thanks, Dan
You'll be fine.
HTH
jimmyfloyd
05-20-2015 07:06 PM
crowtoo
05-11-2015 06:50 PM
