Need help with 2007 Civic LX radio light
Rep Power: 0 Need help with 2007 Civic LX radio light
Hello, I have a 2007 Civic LX with a regular CD/ radio set. I just changed the oil myself, after reset the Maint. minder, the light of my stereo is gone. Is anyone out there can help me? Thanks.
Re: Need help with 2007 Civic LX radio light
Accurately describe your issue. What still works? What doesn't work?
Does the radio still work?
Is just the display inoperative?
Is just the backlight inoperative?
Do the dome lights work?
Remotes work?
Check fuses yet?
Rep Power: 0 Re: Need help with 2007 Civic LX radio light
Yes, they all work. The radio and the dome lights work, the radio display works. Just no light on the buttons. Did I do something wrong when I reset the maint. minder? Thanks
Well that's a bit different from you saying I'd guess you should first make certain that the brightness of the dash light controller is turned all the way up since that set of buttons is right next to the oil change reset buttons......and that the rest of the lighting in the switches still works (see if problem is isolated to the radio only) HINT: the dash light brightness controller also has an internal bulb for illumination, so does the VSA switch and the HVAC panel.
Next step might be inspecting the radio illumination circuits for correct power and ground at the main connectors for the radio, then the radio itself since its illumination circuits are shared with the others listed.
I think that these units use incandescent bulbs for illumination....(you can feel the heat if you touch the buttons when illuminated a while)
Maybe they are wired in series, and one filament failing takes them all out.
Ian SFBA
Interior DIY
04-25-2015 02:25 PM
ashleymmackey
04-18-2015 09:48 PM
chgofirefighter
04-18-2015 08:08 PM
