System setup HELP!!!!
Rep Power: 0 System setup HELP!!!!
I got a 2008 civic with factory nav and i am trying to hook a system in it. I know how to do it in a regualor radio not a factory nav, Can u? do i need anything speacial? I was going to do it old school way and run off the back speakers. Any body with any thoughts?
Re: System setup HELP!!!!
Don't try to mess with the radio and navi units, they are tied together, one can't work without the other.
YES, you could tap into the rear speaker wires like you would with only adding an amp and sub on any other stock radio in a car.
Which car do you have (2 or 4 door, LX EX EXL Si, etc.?) Some have a factory amp under the center of the dash.
Does the car already HAVE a sub in the center of the rear deck? Tap into that and then you can control yours from the deck like stock. (IDK what the spec for the crossover point on the stock sub is though).
Rep Power: 0 Re: System setup HELP!!!!
Its a four door with no sub. I dont know if it has a amp. i was not going to mess with it. I finally found out how to take the nav unit out so i can get to it. It stupid what u have to do to take it out.
It's sooo much easier to look up info for a particular car IF I know what the particular car is.
4 door EX navi shows no amp.
I would have tapped in the wires right at the rear speakers, not at the radio. But OK.
Speaker outs (not line outs) at the back of the navi/radio
Connector A, 17 terminal, gray
LR+, A11, yellow
LR-, A2, brn
RR+, A16, blu
RR-, A8, orn
LR+, A11, yellow
LR-, A2, brn
RR+, A16, blu
RR-, A8, orn
SO.. i am new to hondas and i am puting a system in my wifes 08 civic. I am trying to find a way to get through the fire wall. I was thinking on running the power around to the pass side. Any ideas. I just cant belive that there is no dam room to work in the engine bay.
I'll have to actually look at one to see what might be possible. Can't do that til Monday at the earliest.
Google turned up this: http://www.8thcivic.com/forums/i-c-e...uge-cable.html
Idk if this post is irrelevant now,but I have an '06 with a system...
I got through the firewall using a hole that was already there(Hole was in the sheetmetal,but I had to puncture the carpet like material to get through)
And like e-zone suggested I tapped into my rear speaker wires to hook them up.
I also put 6x9's in
If this post is still relevant let me know and I can post pictures.
I also put 6x9's in
mjdiaz89
06-21-2016 09:26 PM
liagreenhalgh92
07-21-2015 01:31 PM
