Changing led color of instrument panel
Rep Power: 0 Changing led color of instrument panel
Hello, while browsing I came across some pictures of an 8th generation civic with the instrument panel a pink or purplish color instead of the lights being blue and I wanted them instantly! I understand it would be a lot of work but has anyone gotten this done? Also, can the radio light be changed from blue as well?
Rep Power: 787 Re: Changing led color of instrument panel
if you have 8thgen, should be very easy. the regular civics have blue and the SI has red. should be a matter of swapping clusters.
just make sure the new cluster matches the mileage of the old one or as close as you can get. miles are stored in the cluster memory.
Rep Power: 0 Re: Changing led color of instrument panel
Yes, that would be exactly what I would want but wow does that look like a lot of work. I would take it to a shop to do it because I don't know the first thing about this stuff. It turned out great though. Makes me more excited for it!
Instrument panels in older model vehicles can often become damaged or worn over time. This means that vital informationThe instrument panel lights in your vehicle illuminate the dash at night. The instrument panel lights are small light If your wood---or faux-wood---paneling is standing in the way of a much needed room makeover, there are a few way.
how to tie a tie
how to tie a tie
http://howtofreak.com/13/how-to-tie-a-tie
You can learn easily and simply that how to tie a tie at Howtofreak.com.
how to tie a tie
how to tie a tie
trellex
05-24-2015 04:39 PM
One_PeeJay
05-17-2015 05:31 PM
eorlando1
05-17-2015 11:16 AM
NukeSilo
11-20-2001 10:02 PM
