Power Outlet Not Working
Old 01-23-2007
NarcissusAbugan's Avatar
NarcissusAbugan is an unknown quantity at this point
My power outlet isnt working in my 03 civic lx. I would appreciate if someone would help me and tell me how to fix this problem.
Old 01-23-2007
jhwee's Avatar
jhwee is an unknown quantity at this point
Have you checked fuses? I'm not too sure where they are located in the Civics (I drive an Accord - new to the 06 Civic), but they might be under the hood.
Old 01-23-2007
CraigW's Avatar
Start with fuse #18 in the under dash fuse box (15 Amp ).
Each box contains some spare fuses for replacement.
Old 01-25-2007
Bone Stock!
dalaw's Avatar
yup, gotta be the fuse, mine was blown one time
Old 02-12-2007
kokain00's Avatar
kokain00 is an unknown quantity at this point
i have the same car, and there is 2 wires that plug into the adapter behind it and the plug actually fell off, so that might be it if its not a fuse
Old 04-24-2011
mahout's Avatar
mahout is an unknown quantity at this point
Re: Power Outlet Not Working
You can check the fuse firstr but if thats not solving,
Carefully pry out the outlet from the dash. You may find there is not connector to plug the back end into. Seems some Civics were delivered without power outlets and thus the link from the fuse block to the outlet/cigar lighter.
It may help to pry out the covers for options located to the left of ther outlet. Use a sharp blade to start the pry out.
numbersguy
Electrical DIY
09-15-2018 11:24 PM
jbradley4809
04-07-2017 04:23 AM
ORskier
05-03-2015 12:54 PM
mievil
04-28-2015 11:02 PM
mrohitredd
04-15-2015 08:13 PM
Quick Reply: Power Outlet Not Working
