Wheels, Tires & Brakes Modifications Post Wheel, Tire & Brake related modification information and/or questions here.
2013 Honda Civic LX - Upgrade Tires from 15" to 16" ?
Old 03-08-2017
danlee_ca's Avatar
danlee_ca is an unknown quantity at this point
Currently have:
195/65R15
Looking to use a 2009 Chrysler Sebring Touring tires:
P215/65R16
Is this possible, is there anything I need to consider, besides wheel bolts?
Old 03-08-2017
Re: 2013 Honda Civic LX - Upgrade Tires from 15" to 16" ?
You can't fit 16" tires on the stock 15" wheels.
Will wheels from an 09 Chrysler product actually fit and work safely? I can't tell you that but I bet there are websites with that info you can look up.
You need a set of 16" wheels, correct for your particular car, including: correct size (diameter and width), correct offset, correct hub bore diameter (or matching centering rings if aftermarket wheels), correct lug pattern and size
Lugnut seat design must match that used on the new wheels
You will want the wheels to be able to accept your original tire pressure sensors.
The size tire you showed above will be a good bit taller than the original tires so your speedometer will not be accurate, and you may have issues with rubbing fenders and such.
