Wheels, Tires & Brakes Modifications Post Wheel, Tire & Brake related modification information and/or questions here.
torque values , brakes 2010 lx-s
Old 06-17-2016
chuffsy's Avatar
chuffsy is an unknown quantity at this point
I will soon be doing a front brake job 2010 LX-S. New rotors and pads. Can someone furnish me with the necessary torque values for the various bolts. Thanks.
Old 03-06-2017
0396's Avatar
0396 is an unknown quantity at this point
Re: torque values , brakes 2010 lx-s
They are just bolts...simply make sure that you don't tighten them to the point where you're going to sheer off the bolts. You can look up recommended tqr values for bolts by size.. I simply tighten the bolts.. its not like tqr the bolts on the rods in the engine.. I hope this makes sense..if not, buy a Factory Honda repair manual.
Old 03-25-2020
chuffsy's Avatar
So here is what I found
Caliper pin bolts.........................25 ft/lbs
Caliper bracket bolts................. 80 ft/lbs
Bleed Nipple................................7 ft/lbs
kings322
02-24-2011 10:17 AM
Scuracchio
12-28-2006 01:12 AM
macrossranma
05-24-2004 08:09 PM
Metallica454
05-23-2004 02:12 PM
Skunk2ner
07-16-2003 12:29 AM
Quick Reply: torque values , brakes 2010 lx-s
