Wheels, Tires & Brakes Modifications Post Wheel, Tire & Brake related modification information and/or questions here.
Rotor/brake pad/caliper suggestions
Old 04-21-2016
Boofurs's Avatar
Boofurs is an unknown quantity at this point
Does anyone know of a good combo for a 09 si. so my breaks don't wear out as fast as the stock ones?
Old 04-22-2016
Super Moderator
Poopies's Avatar
re: Rotor/brake pad/caliper suggestions
Get your rotors turned at every change and use ceramics. Use engine braking in the higher gears when possible.
Old 04-22-2016
Boofurs's Avatar
I recently just purchased an 09 si. The rotors have been shot to hell and the dealer just slapped on some breaks to sell the car. I'm not apposed to spending money on replacing the breaking system, since all of the research I've done the breaks seam to be what everyone's griping about it. Curious if anyone has found a good solution or a better break system that has seames to null and void any potential headaches.
Old 04-24-2016
Dr Krieger of Modification
mac25's Avatar
Go stock Honda parts, they are safe and will not wear out as fast as upgraded brake parts.
In general People do not upgrade brakes to save money and brake life, they upgrade them for stopping power.
For example if you switch to slotted rotors to add in brake cooling and braking, the slots will cut up your pads much faster.
As well buying cheap parts online is a risk to yourself and others on the road, if you don' know what you are doing/buying please use OEM parts.
Old 05-18-2016
marteam's Avatar
marteam is an unknown quantity at this point
Stoptech rotors + hawk pads is a good combination. Good bite and stopping performance.
Old 06-10-2016
06 EX Mild Mods's Avatar
06 EX Mild Mods has a spectacular aura about06 EX Mild Mods has a spectacular aura about06 EX Mild Mods has a spectacular aura about
I like my brake performance upgrade, drilled and slotted rotors with ceramic pads. Did this about a year ago so I can't report on the longevity of them. Less dust and seem to stop better. See my post on this project.
Sea Bass
03-31-2016 06:52 PM
jsflynn603
03-30-2016 06:33 PM
dsm482
03-27-2016 08:55 PM
redbug2
03-26-2016 08:43 PM
What_It_Do
03-25-2016 01:56 PM
Quick Reply: Rotor/brake pad/caliper suggestions
