2007 honda civic hybrid abs problem
Rep Power: 0 2007 honda civic hybrid abs problem
Hi
Recently i buy the honda civic 2007 hybrid the problem was the battery not worked so i change the battery now the ABS and handbrake light alwas on and break is too hard i check by computer ABS ERR CODE IS 81-01 how i will remove this code
Please help me to solve the problem
Thanks
Thanks
Re: 2007 honda civic hybrid abs problem
This happened after installing a battery??
Which battery? 12v or IMA
How many problems did the car have before you replaced the battery?
On a North American car, the 81-xx series codes represent an internal ABS/VSA control unit fault.....which would seem unusual and rare to me, but certainly not impossible.
These types of codes can set after someone installs aftermarket HID headlight bulbs and places the ballast too close to the ABS control unit, so inspect if your car has this.
Red brake system warning light on, could be faults in the 'advanced hydraulic booster' system..
Is a buzzer in the dashboard also making noise at the same time?
Maybe there are more clues to be found, such as in the brake booster system.
You should check all other control units in the car for fault codes, then evaluate all codes.
Rep Power: 0 Re: 2007 honda civic hybrid abs problem
You should check all other control units in the car for fault codes, then evaluate all codes.[/QUOTE]
Thanks for replay
I replaced the 12v battery while driving it's beep three time and say something in Japanese but i think it's seat belts beep and auto stop not working i checked on computer no error shows just abs and from last night the engine light turns on and after few minutes turns off when start the car it's off but when start driving it turns on and then off no more issues in car no HID installed
Thanks
Thanks for replay
Thanks
Not originally intended to be sold in the Middle East?
Small scanners won't be able to access all the different electronic systems on the car.
Do you have access to a Honda/Acura dealership level scan tool?
61-01
(can be caused by discharged battery)
Have you erased these codes, and do they soon reset again after erased?
My friend have Launch x431 scanner
Can it display live operating data for the ABS system?
I don't think so i will check tomorrow today is Friday and here all market closed
The primary concern is that you have a good battery that will fit securely and connect to the cables safely. You could use a motorcycle battery as long as it is 12v and the cables will attach. (Someone on this forum was using a small garden tractor battery). The original battery (151R ?) was probably not much bigger than a motorcycle battery anyway.
Hi
Thanks
Thanks
What is the problem please answer me
ezprey
05-18-2016 08:50 AM
