Wheels, Tires & Brakes Modifications Post Wheel, Tire & Brake related modification information and/or questions here.
Leaky tires/corroded rims?
Old 02-21-2016
Supertech's Avatar
Supertech is an unknown quantity at this point
I've got a 2008 Civic EX Coupe with stock rims. For quite a while (longer than I can remember) I've had trouble with 2 tires constantly losing air. Over a week pressure on one will drop from 32 to 27 or less. The other is about half as slow. I've remounted tires, put new valve stems in, replaced valve cores, no luck. Tires have been inspected numerous times, no nails, etc. No bubbles when inflated high and tested in in water tub.
I've read elsewhere that the rims can get corroded and prevent a good bead seal. Short of replacing expensive wheels is there any way to polish/refinish the rim to correct corrosion caused air leak? Does anyone know if Honda has any recall or extended warranty for this issue?
Old 02-21-2016
CraigW's Avatar
Re: Leaky tires/corroded rims?
Being 08 you have TPMS correct ?
Did you replace the metal threaded nuts, and rubber washers. And clean the threads on TPMS units ??
Old 02-21-2016
Aluminum corrosion is very common and can affect any aluminum wheel after years of use. Steel wheels too.
Recall or warranty? LOLNope.
Soapy water would show the leaks if you are patient enough.
Leaks are common around the valve stems too. Wheel corrosion and/or TPMS stem corrosion.
Remove the tires, grind/sand/clean all traces of corrosion out of the bead areas and stem area if necessary. Then you can preserve the aluminum however you see fit, or slather the areas with bead sealer and install the tires. Good for a few more years. Repeat with every tire replacement.
Old 02-21-2016
Received 1,437 Likes on 1,193 Posts
I have had a "flat wheel" in the past on one of my cars... It was leaking from a crack on the wheel, so not unheard of.
jdawgzcivic
17
02-01-2020 04:16 PM
bowie
01-21-2018 09:29 PM
09-27-2015 11:33 AM
jerry38
09-20-2015 08:38 AM
MommaLiz
09-07-2015 10:42 PM
Quick Reply: Leaky tires/corroded rims?
