Lightest rims and questions about stretched tires
Rep Power: 0 Lightest rims and questions about stretched tires
Hello, I have a 06 civic lx sedan and I was just looking to get pointed in the right direction to start looking for rims that are lightweight but won't crack during the winter, also I wanted to know does stretching your tires actually do anything or is it just another thing that looks cool and makes your car drive like ****? Thanks in advance for any help.
Re: Lightest rims and questions about stretched tires
1 Post
Rep Power: 170 Re: Lightest rims and questions about stretched tires
If you mean putting a narrow tire on a wide rim, not sure how that looks cool in any way shape or form. Plus it's dangerous for the installer and for the driver.
Personally I think it looks really really stupid and pretty much guarantees you will curb the wheel since there is no tire bulge to protect it.
But if this is your idea of cool, go for it. (keeps the tire shops in business)
Prelude Owner
^ that is a stupid amount of tire stretch and camber!!!
The reason for the tire stretching is to help clear the fender and get the rim "hella flush" to the edge of the fender.
You will want to buy a high quality wheel if you want it to be strong and light. Enkei makes some strong light wheels for a decent price. Konig also.
Dr Krieger of Modification
Hella flush people arnen't into streetable function and definitely not into racing performance.
You usually go to wider aftermarket rims because they can handle a wider tire profile for grip... why would you use a wider rim and stretch a smaller tire?
Just like their camber, it is odd looking and get attention but you would loose grip rather than gain grip by running your camber that negative.
You also can't turn your wheels at speed when you're that low because they will nock your front end off. ...unless you modify the front end =D.
Rep Power: 183 Re: Lightest rims and questions about stretched tires
I would not recommend stretching or cambering any car. There is a reason you do not see "hella flush" cars at the SEMA show, car races, car dealers or respectable human beings garages. It is because it is dangerous, cosmetic only and handles like **** on a stick. You will only see "hella flush" cars at shows and meets, because that is all they are good for.
So, I will let you decide if that sounds like a good idea.
My recommendation is to put your $ under the hood, maybe a quality suspension instead.
Sarahwv2910
22
06-17-2015 12:35 PM
MegaBassX
06-11-2015 08:52 AM
ktdezall
05-16-2015 07:53 PM
