2007 Civic wheel studs
Rep Power: 0 2007 Civic wheel studs
Hi all,
I was just curious if the wheel studs on an 07 civic are prone to seizing or freezing of any sort?
The reason I ask is because I recently snapped one off because it was seized up (the stud broke off inside the lug nut), and I had it replaced by the shop that rotates my tires. A little over a week later, it had become seized back on the wheel stud again. I did not snap the stud off however.
It only seems to be the ones on the front, as the back is just fine.
Anyone have any sort of issues with their civic and wheel studs/lug nuts?
Thanks.
Thanks.
Re: 2007 Civic wheel studs
No, lugnut and stud problems are 99% human caused.
I'd probably want to scrutinize the person that last touched the lugnuts as it sounds like they were severely overtightened.
Rep Power: 183 Re: 2007 Civic wheel studs
If they didn't use a torque wrench on all of your lugs then they are doing it wrong. If you see them using a impact gun, then call them out on it, they know they are being dirtbags when they put it on with the gun.
99% of tire shops are lazy and do not take the time to properly torque wheel lugs, I have to specifically ask for them to do it and watch them, or they will hammer it on with the impact gun.
I hate it, because tire changes are the only time I have to take Toshi to a shop and have dunces touch her. I prefer to bring the wheels down already the car, so that they don't jack stuff up.
+1
There are plenty of mechanics around me that just gun them on with no attempt at torquing.
Got another one or two that use the sticks but can't even get all of the lugnuts tight using the torque sticks.
And when I point this out to anyone, I'm the d!ck.
Then there's some idiot that managed to hammer on a set of wheel locks so tight that we broke like 3 keys on it trying to get them off
(it was not on a Honda product though)
Rep Power: 0 Re: 2007 Civic wheel studs
Here's the weird part. I can get it to turn up until about 1/3rd of the way (when I'm removing it). After that is when it gets tight and seizes up...
It's also dangerous.
Send it back to the last person that installed the lugnuts and make them fix their error.(unless you did it yourself).
Usual scenario: The stud gets stretched by overtightening, then the nut jams up as it tries to pass back over the stretched threads.
Or the tapered end of the nut collapses on the threads when it is buried into the taper on the wheel.
Wrong lug nuts with straight taper (most cars) instead of ball-seat (Honda/Acura) can cause problems like this too.
Fudman
06-02-2015 01:26 PM
