Wheels, Tires & Brakes Modifications Post Wheel, Tire & Brake related modification information and/or questions here.
How to pick rotors?
Old 10-13-2014
jajadub's Avatar
jajadub is an unknown quantity at this point
How to pick rotors?
Can anyone suggest a good pair of rear rotors? I do mostly daily driving but I don't mind upgrading the OEM rotors on my 2006 Civic EX...Also, do I need to specifically pair the pads with the rotors?
Old 10-13-2014
"Honda - tried, true & tested...!"
brags's Avatar
brags is an unknown quantity at this point
Re: How to pick rotors?
I have used ATE ceramic brake pads on 2 previous vehicles with excellent
results. on one vehicle I used the cheaper wagoner rotors in the front with the ceramic ATE pads and brakes felt excellent. on my other vehicle I just changed the
front pads and left the old rotors alone because they specd out ok there was still plenty of thick meat left on them. a little sanding & I was done.. ATE brake hardware (pads/rotors) should be plenty enough in my opinion for what your using your vehicle for. however if you feel its NOT & you need more stopping power AKIBONO performance brake Line up is what I would be looking at.
Brad Andrew
09-08-2015 08:25 PM
Brad Andrew
09-08-2015 08:22 PM
rainman15
09-06-2015 11:10 AM
Quick Reply: How to pick rotors?
