Bad Brakes & Rotors?
Rep Power: 0 Bad Brakes & Rotors?
I have a 2008 Honda Civic LX. I just looked at a blog with a number of people complaining that Honda Civics in a range of production years including this one have had horrible track records with regard to brake and rotor wear. A number of people complained that they had to have their pads replaced and rotors replaced or resurfaced 2 or 3 times before their car had even 20,000 miles on it. I have less than 20,000 miles on mine and have not yet noticed a problem. Should I have the pads and rotors checked? Shouldn't they last 35 or 40K miles?
Re: Bad Brakes & Rotors?
The lifespan of brakes depends entirely on how one drives.
Everyone drives different, no 2 people will have the same brake life.
Brakes only wear when you use them. If you never use the brakes, they would never wear out.
If you only drive cross-country non stop, your brakes might outlast the car.
If you deliver pizza for a living, your brakes probably aren't going to last long.
(If you drive with your left foot on the brake pedal, that's just a bad habit that costs you money.)
I had a friend that drove a rural paper route (actually 3 routes), 250 miles per night. 1/4 mile to 1 mile between the majority of the stops.
Hammer the gas pedal full blast, then stand the car on its nose to stop.
250 miles of this each night.
He replaced brakes every 2-3 months.
You have an LX, it shouldn't need rear brakes for an incredibly long time. Around here, I figure 5:1 longer than the front brakes, or more . An easy 200,000 miles or more for most people.
The fronts are fairly easy to peek at with a mirror and flashlight while changing the oil (IF you go to a shop that does these things). Otherwise, brakes should be checked every time the tires are rotated--since the wheels are out of the way and all.....
If you find your brake life is really too short, Honda does offer some front pads that are supposed to have a longer life---but might be a little noisier than the originals.
Rep Power: 0 Re: Bad Brakes & Rotors?
Thanks, ezone. Sets my mind a ease for the most part. Got another question though. I'm 70 years old and no longer feel safe changing my own oil or doing any other jobs that involve getting under a car plus my floor jack needs an overhaul. Every time I ask for a recommendation for a good mechanic on this or other auto sites, I get zip. Is it most likely that most people on these sites do most of their own simple jobs and almost never have need of a mechanic or is it that I live in Houston and few people on this and other sites live here? What do you think?
Shop finder? http://autorepair.iatn.net/
masongap
05-26-2015 07:55 PM
