Offset not understood...?!
Rep Power: 0 Offset not understood...?!
Hi,
although I manage to understand most of this stuff, I still don't get the offset thing ?!.
but eventually I want to make my car like this:
http://numproduce.com/product.detail_776723_th_3802930
or this:
http://numproduce.com/product.detail_606874_th_2823165
Can I know the rims in the second image in the second link, what offset is it, low or high.
What is the maximum width size that can fit this type of car, I have same type of car.
or this:
A true genius admits that he/she knows nothing.....CLOSED SAT/SUN
Rep Power: 163 Re: Offset not understood...?!
Your photos dont load for me
Offset
Q: What does "offset" mean?
A: The offset of a wheel is the distance from its hub-mounting surface to the centerline of the wheel.
The offset can be one of three types:
Positive Offset: The hub-mounting surface is toward the curbside of the centerline. Positive offset wheels are generally found on front-wheel drive vehicles and some newer rear drive cars.
Zero Offset: The hub-mounting surface is even with the centerline of the wheel.
Negative Offset: The hub-mounting surface is closer to the back or brake side of the wheel%u2019s centerline. Wheels that have a deep-dish look are generally negative offset.
An incorrect offset can cause increased stress on wheel bearings and suspension components, and cause rubbing and handling problems.
Offset
Received 1,440 Likes
Rep Power: 338 Re: Offset not understood...?!
oh, hey, gunner!
howdy.. They finially fix our proxy issues at work.. I can now wither my time away on here when i get free time.
welcome back
Strycker
08-18-2015 02:25 PM
