Grinding noise when starting car
Rep Power: 0 Grinding noise when starting car
I have an '06 Civic LX and I had recently installed a rebuilt transmission and brand new clutch. The problem before was that my input shift messed up from apparently over hauling my old clutch. Mind you this car has 300k + on it.
So anytime I started the car, especially on cold mornings, the car would make this soul wrenching grind and also the rattling sound of the input shaft when the clutch was engaged from inside the car. And since the input shaft was damage, whenever you accelerated there was this "whirling" sound that increased with how much gas you gave the car.
So now, after I did my tranny and clutch replacement a couple days ago, I start my car and I hear that damn grind again. I have no clue as to what it could be. The input shaft doesn't make any sound anymore from the inside, but the grinding came back. Any thoughts?
Thanks!
Thanks!
Re: Grinding noise when starting car
Needs a new starter? Inspect the teeth of the flywheel for damage?
Rep Power: 0 Re: Grinding noise when starting car
Unfortunately, no I nevery really got the chance to ****** a recording of the sound. It happens at the most random times. So far I haven't heard anything from the past that, but if I get the chance I'll post it
