2012 Civic Water boiling noise ehind dashboard
Rep Power: 0 2012 Civic Water boiling noise ehind dashboard
Hello,
I hear a noise that I would describe as water boiling coming from behind of the dashboard.
It is easy to notice when doing sharp turn or driving from even to uneven roads.
Any suggestion?
Thank you.
Any suggestion?
Thank you.
Re: 2012 Civic Water boiling noise ehind dashboard
Is the radiator low?
Is the AC running (defrost mode makes it run even though the light is off)
How about trash rolling back and forth in the wiper area? My yard has a couple sweetgum trees, they drop these awful little bombs
Rep Power: 0 Re: 2012 Civic Water boiling noise ehind dashboard
It really sounds like boiling/sloshing water. Noise level starts low when the engine is cool but the more I drive it the louder it gets.
Water boiling noise....that's an unusual description....not ringing any bells yet.
Got a recording/video?
Have you tried to narrow down a specific area it originates from? Inside the dash, or in the engine compartment?
Tire/suspension?
Does it vibrate instead of make noise? Both noise and vibration?
Tire/suspension?
Rep Power: 125 Re: 2012 Civic Water boiling noise ehind dashboard
Check your inner fenders, Maybe there plugged up with leaves and mud. Not sure it can happen on a Honda but I once had a 69 Firebird Convertible and both front and back would get stopped up and fill up a foot high before coming in on carpet
