Occasional Limp Mode
Rep Power: 0 Occasional Limp Mode
Hey guys! Been having issues as of lately on my 2007 Civic EX. It runs perfect for weeks or months then I get this sputtering and hesitation on the road and it goes into limp mode with the check engine light on. It has happened to my wife most of the time and never when I drive it. I have checked all of the fluids with no issues. Not overheating or anything. When I go and turn it on after these issues, no check engine light is on or any signs of failure. I can't diagnose if no check engine light is lit. Has anyone had similar issues? Is it something that needs cleaning? Any info is appreciated. Haven't found much on these symptoms.
Thanks in advance.
Thanks in advance.
Rep Power: 0 Re: Occasional Limp Mode
Here are some of the codes that popped up when the scanner was plugged in.
P0300, P0301, P0304. A quick search and figured out these where random misfires. I have check the plugs and replaced just prior to these codes popping up.
61-1 -I believe this code is batter voltage drop or something similar.
2-8 -No DTC.
I also did a search and found out other members did a VTEC cleaning and/or screen cleaning of some sort. Could this be the cause of the issue?
Thanks guys!
2-8 -No DTC.
Thanks guys!
