2007 civic ex oil leak?
Old 09-20-2016
steezyr's Avatar
steezyr is an unknown quantity at this point
hello, i just bought a used 2007 civic ex and it turned out its leaking oil.. the mechanic can not see where it is coming from because the car has too much mud/oil residue that grew under the engine. Do any of you know what this could be? I asked the mechanic about the coolant since hopefully it would be coverd by the 10 year engine replacement warranty but he said coolant looked fine.
Any help?
THanks!
Old 09-20-2016
Re: 2007 civic ex oil leak?
I can't see anything from here.
If your mechanic can't tell where the leak starts, he needs to clean off the entire mess so you can start fresh.
Or maybe use UV dye.
Two somewhat common oil leak areas are the chain tensioner access cover and the breather baffle cover on the back of the block.
Simple remove, clean, reseal with fresh Hondabond RTV.
naeem1475
Brakes
05-30-2022 05:51 PM
dabatman99
Engine DIY
15
06-05-2021 07:17 AM
reckless346
03-03-2016 10:45 PM
Jr
12-01-2001 09:20 PM
GreenVenom
11-04-2001 10:56 PM
Quick Reply: 2007 civic ex oil leak?
