2014 EX Civic Econ Mode
Old 06-28-2016
Timbogates's Avatar
Timbogates is an unknown quantity at this point
I have the 1.8L Automatic my question is using the ECON Mode for the transmission. Can you use it in hilly areas? How about in large metropolitian cities which are flat? What is the negative if you use it all the time?? What is the effect on the tranmission?
THANKS
Old 06-28-2016
Re: 2014 EX Civic Econ Mode
Use it whenever you want, you won't hurt anything. Once you push the gas pedal down approximately 80% the ECON functions are disabled, other programs for power kick in.
Copied from another post of mine:
Update on the ECON button functions (remember this button is now on several other models so these may or may not apply to Civics), and keep in mind that there are some trade-offs as far as acceleration, comfort and convenience:
The happy little green light illuminates, and it may modify:
trans controls, (shift points are lowered)
the electronic throttle,
(reduces throttle opening for a given pedal input, while at less than 80% of WOT. At 80% and greater, you still are receiving the normal full throttle response)
climate control, (compressor cycle time and temps, blower fan speed, recirc operation)
cruise control, (limits acceleration/throttle opening rates when engaged, which may allow more vehicle speed variations esp. on hills)
auto-idle-stop for hybrids
. (widened ambient temp ranges allowed for autostop)
johnfa
09-13-2017 12:40 PM
fvckbg
05-21-2016 04:47 PM
onedr
05-01-2016 08:01 AM
CelticOne
04-28-2016 06:37 AM
amctom
04-06-2016 09:33 PM
Quick Reply: 2014 EX Civic Econ Mode
