2006 Si clutch
Old 05-04-2016
timbo007's Avatar
timbo007 is an unknown quantity at this point
2006 Si clutch
I put a comp clutch kit in my si. I am having difficulty shifting gears. I have been told that I need to put a stock clutch kit in order to resolve the shifting problem. Does this sound right or is this an adjustment issue. Do I need to adjust the pedal differently in order for the comp clutch kit to work?
Any advice would be appreciated
Tim
Old 05-04-2016
Re: 2006 Si clutch
Clutch hydraulics are self adjusting. 99% never need touched no matter what you do, unless you replace a master cylinder.
Did you open the line and now it has air trapped in it? Bleed it out.
Suraj Khellawan
08-29-2017 08:50 PM
Phillip Plypots
43
07-01-2016 02:58 PM
j.stoltz
62
04-26-2016 09:30 PM
Reverb2005
04-18-2016 08:51 PM
TravisField1227
04-17-2016 09:51 PM
Quick Reply: 2006 Si clutch
