Rich STFT at idle and crusing
Old 04-17-2016
JackNZ's Avatar
JackNZ is an unknown quantity at this point
Hi guys,
I have a been facing an issue with My honda CIVIC 2006 sedan 1.8 auto. i have been reading data via OBDII for the past few days at cold start to idle and then driving around at cursing speed.
i noticed that the STFT is always with -5 to -20 and the Bank 1 sensor 1 O2 sensor current is averaging at -0.0088 mA and Lambda is averaging at 1.02, while the bank 1 sensor 2 is erratic its averaging 0.56V. the ERG Error is at 99.2 % and the command ERG is mostly at 0, i have attached a CSV with the readings including rpm.
I would appreciate any help here guys i feel lost.https://www.civicforums.com/forums/i...ilies/help.gif
ps: i have already cleaned the ERG valve.
Thank you
File Type: csv
Old 04-17-2016
Dr Krieger of Modification
mac25's Avatar
Re: Rich STFT at idle and crusing
Just a dummy check, but after cleaning, did you make sure the EGR was fully pressed back together for the electrical connection?
(Once I half clicked an ignition coil together and it took me an hour to trouble shoot, because it looked like it was connected, lol. =D)
Old 04-17-2016
Does it run bad? Is the check engine light on? Got codes?
I can't open the CSV file.
Old 04-18-2016
JackNZ's Avatar
Thanks guys, i have check the connectors, and there is no check engine light or trouble codes, the only issue is the idle vibration when the rpm drops below 600 rpm and the car feel kind of heavy
Old 04-18-2016
Computer is still controlling fuel within code-set limits, so I probably wouldn't worry much about it.
What is MAP voltage @hot idle, park/neutral, no load?
Try doing an idle relearn?
Is the vibration harsh and loud? (motor mount collapsed?)
Description is ambiguous.
Old 04-18-2016
JackNZ's Avatar
Hi,
Thanks for the reply, i check the mounts they look fine, and the vibration are not load rather annoying. and the reason i am concerned about it because its not there when the engine is cold ie the ECU is using the default parameters.
i will need to check the MAF voltage and do the idle relearn.
Old 04-18-2016
I said MAP sensor, not MAF.
I kinda judge if valves are too tight by MAP voltage.
BK201
04-03-2016 12:17 PM
Fivespeed5504
03-15-2016 09:23 PM
EdGasket
03-07-2016 05:35 PM
mbolen23
02-01-2016 09:58 PM
coldplayfan
01-25-2016 09:25 PM
Quick Reply: Rich STFT at idle and crusing
