2009 Civic LX-S - hesitation / sluggish / rough idle
Rep Power: 0 2009 Civic LX-S - hesitation / sluggish / rough idle
My 2009 Civic LX-S, automatic, has about 60k miles on it, and lately it's been pretty sluggish, hesitates when accelerating, and idles a bit rough (maybe this is a motor mount problem? Not sure). The car still gets me from point A to B, but it definitely isn't running as good as it did. My first thought was to change some of the basic stuff, plugs, cap, wires, fuel filter, but searching around it's not clear that these things are supposed to be changed this early.
Any tips?
Any tips?
Received 1,440 Likes
Rep Power: 338 Re: 2009 Civic LX-S - hesitation / sluggish on hills
What maintenance did you do so far?
Rep Power: 0 Re: 2009 Civic LX-S - hesitation / sluggish on hills
Thanks for the response.
I haven't done anything specific for this problem yet. So far I've done what the maintenance minder has called for over the life of the car - oil changes, air filter, brakes, along with transmission fluid. The plugs, wires, cap, fuel filter, etc., are all original. I'm assuming there are some basic tune-up type of things I can do myself, so I'm hoping to get some advice here.
Re: 2009 Civic LX-S - hesitation / sluggish / rough idle
Check engine light? Codes?
Crummy or damaged air filter or the air box lid isn't secured correctly, now there's a bug stuck in the MAF sensor?
I'd like to see you TRY to find a distributor, distributor cap and rotor, or plug wires on that engine.
Plugs=100k interval
Fuel filter is built into the tank/pump unit. No service interval, it's an "as needed" basis.
The typical motor mount problem is a harsh vibration or rumble noise, but does not affect performance in the least.
Plugs=100k interval
Rep Power: 0 Re: 2009 Civic LX-S - hesitation / sluggish / rough idle
No CELs.
Wrong wording with the cap - I guess I was thinking coil set I can see wires going to the plugs - are they not replaceable?
Re: the motor mounts, I am definitely having some harsh rumbling at idle - it's just hard to tell if it's because there's something wrong with the engine or the mounts.
Edit: I just pulled off the airbox. The box and the filter are clean as a whistle. I *think* the thing mounted to the inside top of the air box is the MAF sensor? If so, it's pristine as well.
common issue with 8th gen..
The engine mount is hydraulic and eventually sags with normal use. When it reaches near the end of its life, the bump stops would start to bottom out and hit each other, transferring engine vibration to the body. The vibration is more pronounced when the engine is cold or when the transmission is on reverse.
Check the spacing between the bump stops... they should be about 1cm or so away from each other.
My old engine mount:
New:
New:
Awesome reference on the engine mounts - thanks.
I just pulled the MAF sensor - it looks brand new. Nice and clear.
I also pulled one of the spark plugs just for the heck of it, since I've read of good results from other people with similar symptoms replacing them. I'm not expert at these things, but it doesn't look too bad? See attached picture.
Not sure what to try next. The stutter problem is really what I want to resolve. It happens almost every time I go up a hill. If I go up a small hill with light throttle the car will start to stutter. If I give it some more throttle I can usually power through the stutter and the car smooths out.
Plug porcelain and electrodes look perfect in the pic.
Thumb looks dirty.... and do you chew your nails? LOL
If you can keep it stuttering long enough I wonder if it would set a helpful misfire code.
I'll try going really light on the throttle to prolong the stutter next time and see if it will throw a code......
Re: the mounts, browse this thread where those pictures came from and get an idea of when others feel the vibration (Mostly in park, reverse, and deceleration, but usually not while accelerating forward)
https://www.civicforums.com/forums/197-mechanical-problems-vehicle-issues-fix-forum/342963-2008-honda-civic-vibrates-parking-reverse-gear.html#post4577741
My 2011 has the same problem. It is not engine mounts. It idles rough and hesitates when i press gas pedal at around 40-45 mph. I have to press the pedal more before the car responds. I have a 2011 LX-S.
Replace the air filter, plugs and tested the MAF sensor. Problem still there.
Currently, own a 2009 Honda Civic LX-S (5-speed auto) 145.000 miles with the same exact problem. I have been gifted the vehicle from an acquaintance and don't know any maintenance history on the vehicle. Having the same problem as Professor Pmr "It idles rough and hesitates when I press the gas pedal at around 40-45 mph. I have to press the pedal more before the car responds". The only work that's been done on the vehicle by me is an oil change and battery replacement. I will be changing the plugs, filters, and drain/fill the transmission fluid for general maintenance and see if any of that helps. I will re-post on the forum if any of that helps. It would be very helpful if other civic owners/automotively inclined individuals can provide me some advice and point me in a direction. Thanks!
eager2learn
06-11-2017 07:28 AM
97CivicExGlen
09-22-2012 07:38 AM
JapSir
04-14-2011 12:42 PM
poops280z
02-29-2008 02:01 PM
