Regular Maintenance Post Questions/Information about Regular Maintenance here
Time for a tune up
Old 10-05-2015
Stussey21's Avatar
Stussey21 is an unknown quantity at this point
Time for a tune up
Hi I was just wondering if there are and good aftermarket ignition could for an 06 civic 1.8L and what are good spark plugs to use and also are their any aftermarket fuel filter, oil filters that would last longer\ give me more power?
Old 10-05-2015
Mad Dog Tannen's Avatar
Re: Time for a tune up
None of those things will give you more power. Use stock plugs or OEM equivalent.
Are you a troll?
Old 10-05-2015
Stock 99's Avatar
lol.
Old 10-05-2015
Stussey21's Avatar
Okay well what I meant by more power is that I'm sure none of these things have been replaced in well over 100k and if there was anything better to replace them with what would it be.
Old 10-05-2015
I am not sure if any Hondas came with oil filterS, but if the one you do have on there has not been changed in 100k miles, then I am surprised it is still running.
Do all of the preventative maintenance listed in the manual. That should bring it back to par.
Old 10-05-2015
Are you a troll?
+1
I am not sure if any Hondas came with oil filters, but if the one you do have on there has not been changed in 100k miles, then I am surprised it is still running.
Old 10-12-2015
ken4444's Avatar
ken4444 is an unknown quantity at this point
...I'm sure none of these things have been replaced in well over 100k...
Typically the oil filter is replaced when the oil is changed. If you are doing your own oil changes, you should be changing the filter. If you're paying someone else to change the oil, they should be (and probably are) changing the filter.
JohnnyBxo
16
05-09-2015 05:53 PM
Unleaded
06-26-2007 09:25 PM
wawacito
12-14-2001 08:52 PM
Micks2K1
12-10-2001 07:11 PM
SpdRcrChk
11-15-2001 11:33 AM
Quick Reply: Time for a tune up
