driver and passenger window not cleaning
Rep Power: 0 driver and passenger window not cleaning
Hi, I'm new to the forum and I was wondering if anyone else had the same problem I have,
I have a 2014 civic LX, the problem is...when it rain of course the windows get water on them. When I put them down a bit to clean the rain off it doesn't clean. It's like the gasket or whatever it's called does not contact the glass. It's the same for the passenger window...the back 2 windows clean just fine as they go down.
Has anyone else experienced this? Is this a warranty issue?
Re: driver and passenger window not cleaning
Yeah, this has been posted about before.
It's just a thing, I'm fairly certain no windows are DESIGNED with the intent of wiping then as they come up/go down...it's just a helpful side effect of the things that keep water from getting inside the door.
Doesn't bother me at all, and it definitely is NOT a warranty issue.
I can see how it might be slightly annoying if you were used to being able to do it.
timpan
05-18-2015 07:06 AM
