Honda emblem on front
Rep Power: 0 Honda emblem on front
I recently had to replace the honda emblem that is on the front of my 2008 civic. It sits dead center between the hood and the bumper. It is a big silver letter h. This emblem has 2 prongs/studs that fit into 2 holes. Easy enough. Right? Problem is the prongs are straight and slick and once in the holes there is nothing behind the black plastic receiver to hold the emblem on. I'm guessing there was something behind the black plate it fits into to that held it into place but is no longer there. Irregardless, i can't see it and can't get to it.
My solution is to epoxy the studs into the holes and forget about it. What do you think?
Super Moderator
Re: Honda emblem on front
As long as you don't plan on replacing the emblem again, sure epoxy will work.
On a sedan there are push nuts to go on the pins from behind.
On a coupe there were no clips shown in the parts catalog, but it shows a screw there (not sure if it is part of the emblem deal or not)
Rep Power: 0 Re: Honda emblem on front
Thanks for the replies. Removal of assembly to get to back of mounting holes looks somewhat involved and replacing self tapping screws(assuming that might be necessary) is more time than i want to spend on this. I think ill first try the glue approach. If it doesn't work, another emblem is not that expensive.
jessicakaybby
04-20-2015 12:11 PM
Bartkat
20
02-19-2002 01:29 PM
aZnVoYCe
Bolt-on Engine Performance
11-04-2001 10:18 AM
