01 civic transmission problems
Old 06-11-2015
wholt0's Avatar
wholt0 is an unknown quantity at this point
alright I'm new here and I need help a buddy of mine has a 01 lx civic with 1.7l that he did not check the oil level at all and of course blew a hole in the block so he ordered a new motor from eBay the one imported from japan so he paid me to put the motor in it so I pulled the transmission with it so I get everything switch over to the new motor and I start to put the transmission back on the motor I put the torque convertor on the input shaft of the transmission then bolt up the motor to the transmission but not all the way so I could turn the motor over the put the bolts back in the plate to tighten the torque convertor on so I get that done and I'm tightening the motor bolt to the transmission and I heard a loud pop so I pulled everything back apart and check it then put it back to together and it went together good and easy but the cv axels still rotate when I put them in just barely to turn the gears when the transmission is in park so I don't know if I f*cked up the transmission or not
mattdoc
03-14-2017 12:10 PM
bsmiley
04-27-2015 01:27 PM
Rinzlor
04-24-2015 10:33 AM
Richkid23
04-19-2015 12:53 PM
Russps
11-08-2001 02:00 AM
Quick Reply: 01 civic transmission problems
