'06 civic accessory belt won't turn but motor runs
Old 01-27-2015
Kensmith80's Avatar
Kensmith80 is an unknown quantity at this point
My engine started making a very loud noise last night. While driving home, the noise got real bad and I found that my accessory belt is not turning, but the motor runs. Anybody have any clues what might be going on? I have been having some problems starting the car lately but the battery is pretty new and no engine lights or codes showing up. Could this be the alternator locked up or a pulley?
Old 01-27-2015
CraigW's Avatar
Re: '06 civic accessory belt won't turn but motor runs
Something seized.
Take the belt loose and then turn items by hand to locate.
Got to be one HELL of a sound.
Old 01-27-2015
Kensmith80's Avatar
I found the idler pulley to be frozen. About to change it out but there is so little room to work.
Thanks.
Old 01-27-2015
jordan1794's Avatar
jordan1794 is just really nicejordan1794 is just really nicejordan1794 is just really nicejordan1794 is just really nicejordan1794 is just really nice
If you need more space (&I remember correctly) You should be able to remove the passenger tire and plastic fender thing.
Assuming you have jack stands that lift it high enough to get under it that way.
Old 01-27-2015
I unbolt the engine mount and jack the engine up or let it down as needed.
A LOT of room can be gained that way.
Dorval Andre
General 7th Gen
28
07-21-2022 05:53 PM
mattdoc
03-14-2017 12:10 PM
bsmiley
04-27-2015 01:27 PM
vtechcivic
04-21-2015 07:11 PM
Gunner
Engine DIY
10-06-2012 12:37 PM
Quick Reply: '06 civic accessory belt won't turn but motor runs
