09 civic si help!
Rep Power: 0 09 civic si help!
I drove my si then shut it off then tried to start it again and it will turn over but not start fuel pump runs it gets spark coil packs r good & compression is good between 160-200 help!
Super Moderator
Re: 09 civic si help!
It takes fuel+air+spark to keep an engine running. Something is missing.
[QUOTE=bmellott91;4667188]I drove my si then shut it off then tried to start it again
So you just drove it normally to work or something, and it just failed to start? Do you ave any mods on it?
How is the fuel level?
How old is the battery?
How are those fuses looking?
[QUOTE=bmellott91;4667188]it will turn over but not start
If it cranks, the starter is probably ok. Does it sound weak and labored or normal?
How can you tell? You can hear it when you have the ignition in the "ON" position?
How can you tell? Did you check all the spark plugs?
Are they? See above.
Okay. I'll take you at your word.
Coherent sentences save time. Help us help you!
Can you be more specific?
Got codes?
Got angry blinking green key?
Got mileage?
Got oil change history?
locozoko
11-04-2001 05:45 PM
WeRkX
11-01-2001 10:33 PM
