2007 Civic A/C
Rep Power: 0 2007 Civic A/C
The A/C system on my Civic really stinks. I live in Az. When the car is parked in the shade, the A/C works fairly well, but when it's left out in the sun, it's better to roll down the windows. Anyone else have A/C problems?
Super Moderator
Re: 2007 Civic A/C
I used to live in the PHX area for the first four years I had my car. I'd always go windows down until the engine warmed up to its operating temp (doesn't take long out there, does it?), then I could fire up the A/C. Faster speeds also help with the airflow. You're good on freon, right?
Hey, at least it's a dry heat, right?
Re: 2007 Civic A/C
Yep.
Start the car, run the AC on full blast.
Roll down the windows and drive until the interior temp drops from 196+ degrees down to about 120 and cool air is coming out the vents.
Then roll up the windows.
The AC can only drop the air temp about 30 degrees across the evaporator core in one pass. Your interior is nearly 200 sitting in the sun, it takes a long time to cool it down without some help.
Rep Power: 0 Re: 2007 Civic A/C
I'm also in Arizona. The AC's OK, but I did need a recharge this year (an '07). But be careful of who works on it if necessary, other threads here talk about the need for this one thing to be done by the dealer:-(
The AC's OK, and starting out by blowing out the ridiculously hot air is never a bad idea.
Re: 2007 Civic A/C
I think that only applies to the Hybrids that use an IMA powered electric or dual driven belt/IMA compressor, we have a special AC machine for handling them. They use a very special oil in the AC system, any other oil type is considered a contaminant and a possible safety/shock hazard.
Re: 2007 Civic A/C
Yep.
Re: 2007 Civic A/C
The system is supposed to cycle the compressor on and off to keep the temperature of the evaporator core somewhere between ~roughly 3-8 degrees C so it does not freeze.
But if it cycles without good cooling from the dash vents
Some of the more common reasons have been
*AC system overcharged, too much freon
*AC system excessively high pressure on the high side of the system due to lack of air flow, such as radiator fan(s) inoperative or condenser/radiator fins clogged with bugs and sand and dirt
*PCM determines the engine coolant temp indicates overheating and shuts off the compressor
There may be other reasons too.
Also, it's only a Civic. It's an economy car. The AC system is kinda weak compared to some other cars. Even when it works great, it can take a looooooooooong time to cool down a hot interior.
Re: 2007 Civic A/C
tattedlariat
04-20-2015 09:26 PM
Pir8pete
165
03-06-2009 05:16 PM
