2007 Civic SI Shifting Issue
Old 04-23-2014
etorres86's Avatar
etorres86 is an unknown quantity at this point
So I went to take my civic for some servicing, new spark plugs and what-not, also to see if they could fix an issue I have when shifting. Basically, sometimes when I shift to the next gear, it will continue to rev up, and then a couple seconds after I've put it in gear, it will rev down to where it should be.
The mechanic thought it may have to do with some clutch timing, but that didn't end up being the issue, and the only thought he had as to what it may be is an aftermarket Injen Tech air intake that was installed in the car before I bought it.
Could this be the issue? If so, would an OEM intake fix it? If not, what are some ideas of what this could be?
Thank you
Old 04-23-2014
Super Moderator
Poopies's Avatar
Re: 2007 Civic SI Shifting Issue
That doesn't sound like an intake issue to me. So you have manual transmission, right? Have you ever changed the clutch and transmission fluids? That definitely wouldn't hurt anything.
Old 04-23-2014
etorres86's Avatar
It is a 6 speed manual, also the clutch is about a month new. Could it have been an installation issue?
Old 04-23-2014
Super Moderator
Poopies's Avatar
I guess it's possible... What year/trim/body style do you have? What kind of clutch did you get? I'm not so good with transmissions but did you have the same issue before the new clutch?
Old 04-23-2014
etorres86's Avatar
This is a 2007 civic si coupe 2.0L. I have no idea what the clutch was before, nor do I know if it is oem or aftermarket. I got this car after it was already installed.
I was driving around today and noticed it may not have anything to do with shifting. It seems to happen when I accelerate. It'll rev up then catch and start going. It only happens periodically, it's not constant.
Old 04-23-2014
Compare to an identical car if possible.
Dorval Andre
General 7th Gen
28
07-21-2022 05:53 PM
dragonsblood
04-27-2015 12:28 PM
EC3
04-22-2015 07:55 PM
toastyghosty
37
06-10-2002 01:07 AM
toastyghosty
32
12-26-2001 02:03 AM
Quick Reply: 2007 Civic SI Shifting Issue
