2009 honda civic horn problem
Old 04-07-2014
civicswag's Avatar
civicswag is an unknown quantity at this point
hi, i went to use my horn the other day and as i pushed the wheel the horn did not work. when i push the the wheel to use the horn it clicks but nothing comes out, i also found out my third brake light had went out. so the first thing i did was change the fuse(was not blown) and nothing had changed, any suggestions?
Old 04-07-2014
CraigW's Avatar
Re: 2009 honda civic horn problem
The click sound rules out many parts...
You likely have an open coil in the horn itself.
Old 04-07-2014
.....and the center brake light is out.
If it's a bulb, change the bulb.
If it's an LED strip, that's a little more work.
For the horn, I'd see if the wires will light up a test light bulb before sticking a horn in it.
Civicman92296
04-23-2015 09:22 PM
jessicakaybby
04-20-2015 12:11 PM
dooner24
04-14-2015 07:51 PM
bahena08
04-11-2015 05:09 PM
Quick Reply: 2009 honda civic horn problem
