2002 Civic Ex Misfire codes
Old 04-01-2014
stHcivic02's Avatar
stHcivic02 is an unknown quantity at this point
Exclamation 2002 Civic Ex Misfire codes
I have an 02 civic ex and about 1 1/2 weeks ago the check engine light came on, it already had a little bit of a rough idle, but no loss in power, the RPMs didn't even show a change, you could just feel it. I had the codes read at autozone and they were P0300, P0301, P0302, P0303, and P0304. I changed my spark plugs which helped with the rough idle a little so I took it in and was told the valves needed to be adjusted, but other than that everything else looked fine. I had the vavles adjusted about 5 days ago which made the idle feel normal and everything was running great. This morning the light came back on, but it's still running just fine. I'll take it at lunch to have the codes read again but I just wanted to see if anyone else has had this problem and had any advice for me.
Thanks
Old 04-01-2014
stHcivic02's Avatar
Re: 2002 Civic Ex Misfire codes
Just had the codes read and now it's only cylinder 4 misfiring.
CarStuff
12-06-2020 12:52 PM
usajags84
05-10-2015 08:11 AM
smmahan
04-15-2015 08:17 PM
CapYoda
11-11-2001 05:17 PM
Lightman
15
11-08-2001 05:06 PM
Quick Reply: 2002 Civic Ex Misfire codes
