2008 Civic starting issue
Old 11-21-2013
fletch1027's Avatar
fletch1027 is an unknown quantity at this point
I have a 2008 Civic that at times will not start. It happens 4-5 times a year, in the winter, always in the morning when it is below 45 or so. Once the temperature warms up later in the morning it will start. I recorded this and posted on youtube in case this sounds familiar to anyone, because it has me stumped!
[YOUTUBE]bIIi3Lq1Gxg[/YOUTUBE]
Old 11-21-2013
Re: 2008 Civic starting issue
Does it just WHIRRRRRRR but not crank the engine?
If that's what it does, I'd put a starter in it because the bendix isn't getting kicked out.
Old 12-01-2013
desmo888's Avatar
desmo888 is an unknown quantity at this point
Have you checked the battery terminals for corrosion? I once had a similar problem with a Nissan. Took off the plastic covers on the battery terminals and the negative lead was covered in corrosion. Cleaned them both up and all was fine. I think winter salt (I lived in Boston at the time) contributed to the problem.
Old 01-08-2014
sdraza1's Avatar
sdraza1 is an unknown quantity at this point
It happened to me too today. I went out of country for about 2 weeks and perhaps battery couldn't be charged. I am thinking of warming the battery with hair dryer and will try to restart it.
Old 01-08-2014
Forget it. If the battery went dead and it's in the cold, it's frozen inside. It is considered junk now.
Replace it and get it over with.
If you have a starter problem as the OP did, that's different.
usajags84
05-10-2015 08:11 AM
Braun
04-23-2015 09:03 PM
Civicchicky87
Idle Issues
04-22-2015 07:16 PM
civic_gt
04-19-2015 08:15 AM
mugenca
04-16-2015 12:15 AM
Quick Reply: 2008 Civic starting issue
