2006 DX - rough manual shift
Rep Power: 0 2006 DX - rough manual shift
I've read quite a few posts about rough manual shifting, but nothing is quite like what I'm experiencing.
Upon pushing down on the gas after any gear change (1-2, 2-3 etc..) I'll experience a jerk. This happens at low or high rpm, and it almost seems that it's not responding quickly enough to the gas after letting go during shift. Also while driving if I let go of the gas while in gear and quickly press down, the car jerks a bit. This may be normal and not related to the shift problem though...
Any help/insight would be much appreciated. Thanks.
Re: 2006 DX - rough manual shift
Have you driven another identical Civic to compare?
I'd suggest you do this first.
Is your check engine light on?
Rep Power: 0 Re: 2006 DX - rough manual shift
Oh, and no, no engine light on.
Fly-by-wire does feel a little different from a cable operated throttle, it took me just a little getting used to the first few times I drove them back when Honda first started using them.
Some other manufacturers have been using them for well over a decade already. They definitely do not all react the same, some manufacturers' products have a definite lag in response time. Others react dang quick.
Foot timing is everything LOL.
I might drive 50 different cars in a week. I can adapt pretty fast.
Edit: I bought this 2006 approx. 3 years ago, and this weird issue has always existed.
I'd think that finding an identical manual trans Civic 06-11 would make a good comparison.
Or get someone intimately familiar with the cars to give it a quick test drive to see if something obviously isn't right.
Go to a dealer for an oil change? Ask for a senior (a well experienced) tech to give it a quick drive, describe your issue so he knows what you are after. To someone like me, it should be quickly apparent if the car drives like most others or not.
The reason I say that is at our shop, a quick 1-2 mile test drive just to confirm a complaint could be free...but to go any further in the diagnosis will cost you.
You decide the next step.
HTH
HTH
Burnout
07-15-2022 10:24 PM
97-DX-Lover
06-14-2015 06:07 PM
