speedbump Clunk on passenger side.
Old 08-18-2013
chris015's Avatar
chris015 is an unknown quantity at this point
06 civic LX. AT. 1.8
Helping a friend diagnosis his car. It has a faint clunk on bumps etc on the front passenger side. I took a look at it tonight. Swapbar links are good,cv axles good,balljoints are tight (did the 12 and 6 oclock wobble test). Control arm bushings seemed ok.
Im leaning towards the strut tower,or lower engine mount. I couldnt tell if the mount was bad,but the center of it looked a little wet inside where the little stub is above the mount. It had a "cut" in a circular motion around the stud. Normal? We took it around the block,ive never been in one so i didnt know how much vibration was normal,but i noticed very little. The dogbone part of the upper mount looked good.
Any help would be awesome.
Old 08-19-2013
Prelude Owner
GolNat's Avatar
Re: speedbump Clunk on passenger side.
Did you inspect the upper strut mount? Sounds like that could be the issue.
Old 08-19-2013
chris015's Avatar
I didnt. It was getting late and we were in a busy apartment parking lot. All i could do with the strut was bounce the car up and down. No noises and the strut its self is still good and solid.
Also...Who thought it was a good idea of putting the upper mount of the strut up inside the windshield cowl? lol I noticed like a little square door. Do i pop that open to get access?
Old 08-19-2013
Prelude Owner
GolNat's Avatar
I don't own an 8th gen civic so I am not sure. That would be stupid though!
Not as stupid as having to remove the bumper to replace the battery like Chrysler does.
Old 08-20-2013
chris015's Avatar
Well,he took it by the dealership to see what they thought.
Rear shocks are leaking fluid,and they believe the front strut is making the clunk. Mounts fine.
I'll be doing to work. We are going to have a shop swap the struts (i dont like springs lol) Im just removing and installing the parts onto the vehicle. The dealership said there was a trick to the rear ones..
whats the "trick"
SammySC
121
04-07-2017 07:43 PM
fvckbg
10-20-2016 07:37 PM
lowlife9
10-06-2015 04:39 PM
Wariogamer
09-29-2015 09:49 AM
rovafa2002
09-28-2015 06:57 PM
Quick Reply: speedbump Clunk on passenger side.
