09 lx-s motor flooding with gas
Rep Power: 0 09 lx-s motor flooding with gas
i have a 09 civic lx-s. i bought it when it had 15k miles, ran amazing until 35k. one morning it didnt want to start. i forced it to start but it had trouble keeping it running, kept forcing it and finally ran good after starting it for 5-10 mins. after it ran for a while i would shut it off and start with no problem right away. check engine light went on, multiple spark plugs misfiring. swapped the plugs and did the same still. brought it to the dealer and they never heard of this. so they ran diagnostics and sparks misfiring again. they changed them again and still same issue. they thought it was ECM, put a new one in and still the same issue. so they put my old one in since it wasnt it. they said that the flue keeps flooding the motor and the fuel is not shutting off and over night it builds up and cant start and when i start it, it burns off when i force it. thats why its hard to start in the mornings since its not running over night and easy to start after i force it. so they gave up, told me to get my car since they cant figure it out.... please help!
Re: 09 lx-s motor flooding with gas
OK
Sounds like either it is something you are doing, or you need a better dealer with smarter employees.
Sounds like engine is flooded with fuel.
Is the battery good? Cranks nice and fast?
Is the gas good? Not months old gas?
It is easy to flood almost any engine if you start it up and move it 20 feet, then shut it off. (Like moving one car out of the driveway to let another car out.)
Could this be your case? (Fix: Stop doing that!)
If the engine floods, push the gas pedal to the floor while you crank it. Hopefully this can help dry the plugs and get it to run again.
We deal with this a lot with new cars in the winter, sales department plays "parking lot rodeo" and usually floods at least a few of them. Flooded, dead batteries, and out of gas. Not all the cars, but some of them. Every time.
The engine needs to reach operating temperature in order to keep it from "loading up" with carbon and gas. Meaning you need to DRIVE it and get it all warmed up before you shut it off again.
Got any more info, more to the story?
Rep Power: 0 Re: 09 lx-s motor flooding with gas
It pumps fuel constently in the motor... something is wrong with the car... after I force it to start, it start s fine... like something is not letting the fuel stop pumping. I broght it to a mechanic and he is one of the best in town and he is still trying to find what keeps it flooding and he has been looking for 3 days.....
You didn't answer this...Did you do this?
if you start it up and move it 20 feet, then shut it off. (Like moving one car out of the driveway to let another car out.) Your battery would be dead if the fuel pump was running all night. It isn't.
I don't care how good anyone is. If they aren't properly equipped and tooled to deal with these cars, he's probably not going to figure out much.
I can look like a smart **** as long as I have the right equipment. Give me a car with a problem that I'm not equipped to deal with and I can look like I should just change the oil.
Does the engine have proper (full) power once it runs?
freyes23
06-21-2015 10:37 AM
Supramk3
05-11-2015 07:55 PM
tylerginevan
04-27-2015 12:29 PM
